looking at foton 824
   / looking at foton 824 #11
I have a foton 824 its loud as **** in the cab, the air sucks, had trouble with the hyd but after three trips from the dealer its fixed, and last of all we had to fix the clutch after three years and about 3000 bails of hay later. All we use this tractor for is cutting and some raking. Its a good tractor all in all. We own john deeres that cost so **** much, so we were trying someting cheaper out and thats what we got. After raging on it its good for cutting, raking, mowing. Its 4x4 is awsome we own feed lots and mud is always an issue but it goes right threw. The real question is would i buy one again if i was a younger guy yes for me to run no, But my kids yes there younger and can handle the butt kicking your going to get running this thing threw a field. I can buy two of these to one deere so cost is good. Power is good but they need to do something about the air it sucks bad. tint the windows and add padding to the hole inside and it helps alot. Hope this helps. need anything else hit me up.
   / looking at foton 824 #12
A small dealer about an hour from me dyno'd one about a couple of years ago, came in at 95hp pto if I remember correctly. I think they have a perkins which are good engines.
   / looking at foton 824 #13
In reality it's a Perkins clone. Chinese industry in general seems uninterested in conforming to patent law (relative to international treaties)
//greg//
   / looking at foton 824 #14
   / looking at foton 824 #15
I would pass on it if it were me. My dad has a Foton 904 with 712 hrs on it now.He bought it new for around $22,000 4x4 cab air radio no loader. We have farmed our whole life and had many different tractors. Before I bash it I should say it will get the work done your talking about, exactly what we do with ours.
But like some others have said it is loud in the cab, the ac is poorly designed and will not keep you cool inside if outside temp is above 85. We have tint and plugged up all the holes we could and there are plenty. Paint is terrible there is no primer so it comes off and starts to rust. The radio just makes more noise so it is useless. The exhaust pipe looks like a muffler but if you take it off you can see through it, just a straight pipe. I would like too say to the other poster that a 1066IH would be loud, but a good loud. Not just gear whine and engine knocking away. The seat is about the same as a lawnmower seat.
As for breakdowns here is a sort of list :rpm sensor,pto shaft snapped off,power steering leak under dash. that all I can remember. I am mowing crp ground now with a bush hog 2415. I get 2or3 hour in the morning then it gets too hot for me and the tractor. Also it don't have a inner air filter. My advise too you sir is too go buy a forty year old USA tractor in good cond. you will be alot better off. Lildobr
2021 Ford F-150 Ext Cab 4X4 Pickup Truck (A55852)
2021 Ford F-150...
2019 Dodge Charger Sedan (A55853)
2019 Dodge Charger...
HEAVY DUTY JACK (A54757)
HEAVY DUTY JACK...
Hawk X-Pro Gas Dirt Bike (A55853)
Hawk X-Pro Gas...
2016 John Deere Gator (A55973)
2016 John Deere...
UNUSED FUTURE FT-RP72 - 72" HYD ROCK CRUSHER (A52706)
UNUSED FUTURE...
