Looking for 55 HP Kubota, 2 or 4 wheel?
   / Looking for 55 HP Kubota, 2 or 4 wheel? #12
I say 2wd should be illegal (in jest since I own 1) cause the minor incremental cost is way worth more than it costs. There are applications for 2wd but 4wd is so much more productive and effective.
   / Looking for 55 HP Kubota, 2 or 4 wheel? #13
............I do plowing, harrowing, spraying with mounted sprayers, your typical range of pulling exercises......
Guessing if you have a 40 hp JD that's worn out, it is (1) probably old-school and makes 40 pto hp at 1800 engine rpm, and (2) weighs over 5000 pounds bare. It might take an M7040 4wd limited slip to get similar tractive ground engagement.
   / Looking for 55 HP Kubota, 2 or 4 wheel? #14
I would agree that old school 40hp is hard to compare to current tractors but with 4wd does make everything work better, just remeber you can't replace old fashion pounds on the ground for plowing. I say that most with they would have 4wd @ some point. Wish you luck in your search.
2021 CAN-AM OUTLANDER 650 XMR 4-WHEELER (A51406)
2021 CAN-AM...
Quick Attach Skid Steer Quick Claw Grapple Industrial Grapple Rake (A53473)
Quick Attach Skid...
1994 Toyota 6000lbs 2 Stage Forklift (A53472)
1994 Toyota...
2021 JOHN DEERE HX14 LOT NUMBER 14 (A53084)
2021 JOHN DEERE...
2020 Nissan Rogue SUV (A51694)
2020 Nissan Rogue...
2012 CATERPILLAR 304E CR EXCAVATOR (A51242)
2012 CATERPILLAR...
