Looking for 90mmm ID shim
/ Looking for 90mmm ID shim #1
liberty2701
Platinum Member
Lakes region,NH
Kioti Dk50se hst
I am having a hard time locating a 90mm ID shim for an excavator pivot pin. Trying to purchase from other than the OE. Any ideas on a good supplier?
/ Looking for 90mmm ID shim #2
How thick? How many? What material? Is the OD critical, or can it be from, say, 150 mm to 180 mm? Can the ID vary slightly?
On my main boom pivot the shim split and popped out. 2mm thick. ID not critical but close. OD has more leeway. What ever material is most durable
/ Looking for 90mmm ID shim #4
Thicker than I thought, as that's very close to 14 gauge—certainly close enough to use! Consider getting some stainless steel stock and cutting them out, if necessary (or ordinary cold rolled, if it's kept greasy to prevent rust.) A cheap hole saw will get you a couple made before it gives out! (Yeah, I've done this sort of thing.) You could even use some of the stronger bronze stocks, at a higher cost.
I am looking to replace what came out. It is a shim on the main pivot. The oe shows it in the schematic. I figured they put it in for a reason.
/ Looking for 90mmm ID shim #8
someone with a CNC plasma torch, there really fairly common, and could cut most any metal, many small general fabrication shops have one,
/ Looking for 90mmm ID shim #9
Hold on I might have something. well get back to you tomorrow night.
Brock 48'x16' Flat Bottom Grain Storage Tank (A57148)
Brock 48'x16' Flat...
2019 Ford F-350 (A55973)
2019 Ford F-350...
CATERPILLAR 72" HANG-ON WHEEL LOADER FORKS (A60429)
CATERPILLAR 72"...
(2) 6 LUG WHEELS/GOODRIDE ST225/75D15 TIRES (A60432)
(2) 6 LUG...
INGERSOLL RAND G25 GENERATOR (A58216)
INGERSOLL RAND G25...
2 - WEATHER GUARD TOOLBOXES (A55745)
2 - WEATHER GUARD...
