Looking for a Ford for 4 acres - Vineyard
   / Looking for a Ford for 4 acres - Vineyard #11
Are the 2000 and the 3000 both 3 cyl models ( post 1965 ).. the 2000 could be a 63/64 model and be a 4 cyl.
If both 3-cyl.. then both are pretty close tractors in capability for what you will be doing... If the diesel is in good condition and starts easy, cold, with no ether.. and is in as good a condition as the gasser 2000.. it would be my choice.. though.. if something does go wrong.. the gasser is a tad easier to maintain for small stuff in the ignition.. etc.. ( Ie.. sounds like a win-win situation to me.. )
soundguy
The 2000 is a 4cly gas and is in better shape - I am leaning towards this one.
The one issue is neither have mowers or loaders. I think this might be expensive later on - for a belly type mower.
   / Looking for a Ford for 4 acres - Vineyard #13
Keep in mind the 2000 4 cyl is more or less a 'newer' 601 series tractor... pretty reliable.. but 99.9% different than the redesigned 3 cyl models.
I'm more familiar with the 4 cyl models anyway.. so if you have any questions.. let me know..
sounduy
Are there many options for belly type mowers?
Or am I limited to the woods.
I guess I should try out a rear finish mower first.
   / Looking for a Ford for 4 acres - Vineyard #15
I've only seen woods finish mowers under them.. but for the money.. a rear mower usually works out ok..
soundguy
   / Looking for a Ford for 4 acres - Vineyard #16
I have no idea what size and type of sprayer.
I have never done this before.
What do you suggest?
   / Looking for a Ford for 4 acres - Vineyard #18
Well, that is what I was referring to earlier. You need to decide what size and type sprayer you are going to use and buy a tractor that can handle it. There is no sense in buying a tractor too small for the sprayer.
I have never used a Jacto sprayer yet but I am strongly looking at buying one as they look very well built and are priced well. They have some nice features also but are rather new in my area. Here is a small 3pt mounted unit they sell that only requires 18 pto hp. However, a 50 gallon tank will only do a half acre as you want to put 100 gallons of water on per acre. So 2 acres would require you to fill up 4 times which gets old but it is an option.
Jacto: Arbus 200 Airblast Sprayer
Now if you go with a 100 gallon tank it will do an acre per fill up but you need a 40pto hp tractor (and I agree from experience). This tank weighs 640 pounds empty plus the 800 pounds of water and you have almost 3/4 ton hanging off the back of the tractor which is a lot for a small, light tractor (my 1920 struggled with the weight more then power on the 100 gallon 3pt Berthoud sprayer I used)
http://www.jacto.com/sprayers/agricultural/airblast/arbus_400.html
However, if you go with a 150 gallon trailer sprayer you can get by with 20 pto hp on flat ground. I have looked this sprayer over well and it is very well built and balanced. However, if you are on hills you will want a bigger tractor in front of it as it will push a small tractor around.
Jacto: Arbus 500 Airblast Sprayer
Any larger a sprayer then the Arbus 500 and you will need considerably more power to run the pump and handle the sprayer. But for your acerage I would go with the trailer unit for two reasons, you can use a smaller tractor (as long as your on flat ground) and the trailer sprayer is a lot easier to hook up then the 3pt air blast sprayers. They build the 3pt units so they hug the back of the tractor to keep the weight close to the tractor but by doing so it makes it very tough to hook them up.
If you do go with a loader on the tractor and it isn't quick detach you will want to keep it up in the vineyard and pay close attention in your orchard as if you forget about it one time it will do a lot of damage to a tree or vineyard. They are not very handy in orchards and vineyards and more of a liablility so if you can get a quick attach/detach loader then you will have the best of both worlds. I finally put the loader back on my 1920 as it has been off since early spring when I started working in my vineyards and orchard this year.
What exactly are you using the sprayer for?
The ones I have seen in my area are just trailers that are pulled around.
They have gas motors that run the pump.
Won't something like this work?
   / Looking for a Ford for 4 acres - Vineyard #20
Ditto that.. anything more than about 50g on a small ford and you want to go to a trailered sprayer setup.
soundguy
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A53473)
PENDING SELLER...
2008 Ford F-550 Reading Enclosed Service Truck (A52377)
2008 Ford F-550...
2014 KOMATSU PC490 LC-10 CRAWLER EXCAVATOR (A52576)
2014 KOMATSU PC490...
2018 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2018 Allmand...
JOHN DEERE 4066R LOT NUMBER 23 (A53084)
JOHN DEERE 4066R...
Hydraulic Hose Reel (A52377)
Hydraulic Hose...
