Looking for a manufacturer/seller of premade fuel lines
   / Looking for a manufacturer/seller of premade fuel lines
i still vote for a quality double flaring tool and do it yourself. no custom fittings as you use the same as stock ones.
it would be a lot easier to determine the extent of what i need to replace if i had it up on a lift, but from what i can see from underneath, the majority of the rust is the connections. all the connections in question are quick connects. it's not a matter of a barrel splice and a couple of double flare fittings - it's the area around the disconnects that is bad. i haven't looked too carefully, but i've never seen any of those disconnects that accept a threaded flared fitting. if you know of a place, by all means, give me a link. this is roughly what the disconnects look like:
Google Image Result for http://www.troublecodes.net/members/op1/fuellineconnector.jpg
2016 Peterbilt 567 Tri-Axle Dump Truck (A51692)
2016 Peterbilt 567...
2003 Pierce Spartan Pumper Fire Truck (A51692)
2003 Pierce...
2013 Cadillac SRX (A50324)
2013 Cadillac SRX...
Bobcat Sweeper/Bucket  72"  (A52384)
Bobcat...
2012 UNVERFERTH 6-INCH FRONT WHEEL SPACER KIT FOR 10 BOLT HUB (A53473)
2012 UNVERFERTH...
2018 Ford Explorer AWD SUV (A51694)
2018 Ford Explorer...
