Looking for advice on rotary cutter
   / Looking for advice on rotary cutter #1
Northern, MN
JD 4600
This is a little complicated, so please bear with me
I currently have a 16yo JD4600 with a Squeeler 720. The tractor has 570 hours, about 275 of that would be using the SQ720. This tractor has rear wheel weights and rear tires are filled with fluid, so it痴 very heavy.
The SQ720 is working great, even though it looks like it痴 been mowing a mine field. The gear box is tight, and is not leaking any fluid.
We are considering the purchase of an additional smaller tractor, a 2032R (MY2017, to get the heavier, updated unit). This will have the MMM and a brush cutter as well. We need a smaller tractor to transport between our two farms. The dealer is quoting an RC2060 on this unit.
So what痴 the purpose of this post? There痴 several things I知 considering
A lot of my mowing is over hanging fence lines which I have to back into. Because of this, the tail wheel on the SQ720 is pretty beat up. I am concerned, looking at the RC2060, that the tail wheel is only held on by a single square bar. I知 pretty convinced I would have destroyed the tail wheel on an RC2060 by now, same with the MX5, which I am considering upgrading to. The SQ720痴 tail wheel is securely mounted using a triangle type mount.
Ideally, it would be nice if I could use the SQ720 on the 2032R, but I think it might be a little big for it
So, my thoughts/questions
Should I just try the SQ720 on the 2032R and see how it goes?
What is the service life of a SQ720? Given it痴 age, should I keep it and drive it into the ground, or should I send it down the line while it still has some economic value and use that towards a shiny new one?
I kind of hate having two rotary cutters that are basically the same?ut I think a 6 is going to be too big for the little tractor and the 5 is going to be too small for the big tractor (can稚 get up close to the sides of things).
Thanks for any thoughts/suggestions.
   / Looking for advice on rotary cutter #2
First thing that comes to mind is can you find a cutter that you could mount offset to get under the overhanging, then remount for the rest of the field?
If you have a LOT of backing to do it would probably save a lot of time.
As far as size goes - I run a 5 on my M4700 (50HP) simply because my relative was selling it.
Looking at the cost of a new RC2060 I'd definitely try the 720 FIRST, before deciding it was TOO big. Size depends a lot on the thickess of what your cutting.
   / Looking for advice on rotary cutter #3
My SQ60 has about 800 hours,used on three different tractors.I don't care what it looks like but it works well.The 6ft. may work on your smaller tractor for light stuff.I would run it until it quits.
SKLP Windmill Shooting Target (A53316)
SKLP Windmill...
2007 Volvo VNL Truck Tractor (A55301)
2007 Volvo VNL...
2023 54' Hooklift Dumpster 15 Cubic Yard (A55788)
2023 54' Hooklift...
2018 WACKER NEUSON RTSC3 ROLLER (A52576)
2018 WACKER NEUSON...
2011 CHEVROLET EXPRESS SERVICE VAN (A51406)
2011 CHEVROLET...
2020 Ford F-150 Crew Cab Pickup Truck (A55788)
2020 Ford F-150...
