Looking for an odd size bolt
   / Looking for an odd size bolt #1
queen of spades
Anyone know where I can get this bolt:
7/16" hardened hex bolt (grade 8)
1 1/4" length
Important: I need 1/2" of the bolt shouldered. That's the hard part.. most shorter length hex bolts have threads all the way to the head. Have to have the 1/2 shoulder for the application.
(fwiw I've already been to ACE, box stores and a local Fastenal outlet)
   / Looking for an odd size bolt #2
That is kind of an odd bolt. If I'm reading your post correctly, you need a bolt threaded to within 1/2" of the head and that 1/2 inch should be the shoulder...not a typical shoulder bolt.
You can try companies that specialize in fasteners (rather then a hardware store). Do an internet search for "Fasteners" and "Bolts" to find a company close to you. One that comes to mind is a company named Fastenal, but I have no idea if they have an outlet near you.
The other possibility is this is a bolt made specially for a particular application. If that's the case, you'll need to contact the manufacturer of the tool or equipment you need it for (example: if you're working on a 1970 John Deere tractor, you'd need to contact a Deere dealer to buy the replacement bolt).
   / Looking for an odd size bolt #3
Can you cut back a longer bolt that has a shoulder?
I doubt anyone made a bolt special for that application. I'm sure the right supplier will have it for you. Ford/Dearborn was famous for using 7/16" bolts. Try a New Holand dealer.
   / Looking for an odd size bolt #4
Why do you need 1/2" shouldered? Are you using them for a Tension or Shear type of clamp up. Most ready made Grade 8 short bolts are fully threaded unless you order them special order or from a machine shop and it will really cost you.
Jim
   / Looking for an odd size bolt #5
Mcmaster Carr 91257A675
Closest I found 1 3/4 long have to buy 10 shoulder length is maybe
anyway take a look .
Not with 60 hardened fasteners.
I'll try this once..
The Italian tiller I bought (used, and with no model# anywhere) needed replacement tines. The closest I found was Caroli replacement tines. They have the same shape and hole alignment, but the holes are once size too small.
I tried drilling the holes larger with a carbide tipped bit and my 2hp drill press - barely scratched the surface.
So my only option is to put in 7/16" bolts. If I absolutely had to I could use non-shouldered bolts but that's not what came on it. I need to get as much metal-to-metal contact as these bolts will see a LOT of abuse.
Good site... those will be a bit long.
   / Looking for an odd size bolt #8
I've never had a problem shortening grade 60 bolts. Done it a number of times. I doubt that in that application it will make a difference but perhaps. Good luck
   / Looking for an odd size bolt #9
Yea, a good cutoff blade in a small grinder will make short work of a grade 8 bolt.
   / Looking for an odd size bolt #10
If the tiller is Italian, it's probably metric. Why don't you replace with the proper metric size? M12 is slightly larger than 7/16". McMaster-Carr sells the metric grade 10.9 in both fully threaded and partially threaded lengths.
1-1/4" ~ 31 mm McMaster # 98093A751 is 30 mm fully threaded
and 1-3/4" ~ 45 mm McMaster # 98093A766 is partially threaded
Cut-off the excess with a cut-off saw blade.
John Deere 772-A Grader (A52384)
John Deere 772-A...
Kawasaki Mule 4010 UTV (A53117)
Kawasaki Mule 4010...
PALLET OF EXTENSION CORDS AND AIR HOSES (A53843)
PALLET OF...
2025 Swict 66in Bucket Skid Steer Attachment (A51691)
2025 Swict 66in...
Gooseneck Livestock Stock Trailer - Tandem Axle Ranch Hauler - Selling Absolute, No Reserve (A53473)
Gooseneck...
2020 Polaris Ranger 1000 4x4 Utility Cart (A51691)
2020 Polaris...
