Hooked_on_HP
Veteran Member
Yea, a good cutoff blade in a small grinder will make short work of a grade 8 bolt.
I think they will have to cut off 60 bolts.
Bill
If the tiller is Italian, it's probably metric. Why don't you replace with the proper metric size? M12 is slightly larger than 7/16". McMaster-Carr sells the metric grade 10.9 in both fully threaded and partially threaded lengths.
Bill
Iron Horse beat me to it. Just cut some bushings out of tubing to take up the space of the larger holes.Get some thin wall steel tubing and cut off 60 bushes that will step the tyne holes down to the bolt size you are using . A power hacksaw , bandsaw or a drop saw can do this if you use a positive stop so all are the same length .
Queen, Check BoltDepot.com. They have a shouldered bolt section if I recall right. I have ordered several times from them and they are fast and probably the lowest priced you will find.
Huey
