Looking for Hydrolic pressure gauge
   / Looking for Hydrolic pressure gauge #1
roma3112
metro boston
simplicity 3112h
Folks
Was looking for an innexpensive hydrolic pressure gauge to use for my bx24 and some other equipment i have. I was wondering what you folks may have/use. While I dont plan on messing with the bx's settings I want to have one so I can have it as part of my normal maintenance check-up routine.
thanks
   / Looking for Hydrolic pressure gauge #2
Folks
thanks
Northern Tool has inexpensive, accurate oil filled gauges in a lot of different configurations on the shelf, also Tractor Supply has a good selection as well as any adapters and fixed length hydraulic hoses you may need. NAPA also comes to mind.
any special type, calibration, min/max pressure rating I should be looking for? Also If I were to build my own for a bx24 do any of you folks know what type (brand) of hyd quick disconnects I need? The bx24 kubota uses a kind that I cant get at napa. I remeber having a problem with the quick disconect on my bx24 loader I had both ends of the fitting with me and the guy looked through the book, and shelf stock for quite a bit and could not find the exact match.
   / Looking for Hydrolic pressure gauge #5
roma, what I did was I saw a liquid filled gauge on clearance at horrible frieght - oh I mean harbor frieght and got that. I borrowed the coupling from my backhoe when it was off for the test. Can't go any cheaper. ;)
If you want to order extra connectors, here is the info:
Snap-Tite coupler = 72C4-4F NPT
Snap-Tite nipple = 72N4-4F NPT
the pressure should be Factory spec. for hydraulic relief valve activation is from 1778-1849 psi.
there has been a few threads on this, try doing a search and you wil have a few hours of readings:thumbsup:
377811 (A48836)
377811 (A48836)
2016 Big Tex 14ft. T/A Hydraulic Dump Trailer (A50322)
2016 Big Tex 14ft...
2013 Chevrolet Cruze LS Sedan (A50324)
2013 Chevrolet...
2015 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A52576)
2015 FREIGHTLINER...
2002 Kountry Star Motorhome (A50324)
2002 Kountry Star...
2015 Jeep Wrangler Multipurpose Vehicle (MPV), VIN # 1C4BJWEG5FL757630 (A51572)
2015 Jeep Wrangler...
