DieselBound
Elite Member
A couple of my fence lines (looking to fence in about 6 square acres) have ditches on the outside. I won't be able to work from the ditch side, in which case I figure I'll have to bring up the wire (woven wire) on the inside of the end posts. Crudely, it would look something like this ("O" = end posts; "+" = line posts; "__" = wire [woven wire, fixed knot, is what I have planned for]):
~~~~ ditch ~~~~
O____+____+____O
~~~inner side~~~
Now, then, coming off these corners/end posts I have a need (based on maintenance and installation difficulties) to bring the wire up from the OUTSIDE of the end posts. Coming down one side of the fence line the wire will be on the inside and then the adjoining fence line the wire will be running on the outside of the end posts.
I know that the general rule of which side to run wire on is based on which side presents the need to withstand the greatest pressure (keeping things IN or keeping things OUT- with horses it works backwards- you want to allow some give when horses hit the fence, so with horses wire tends to be placed on the outside of the posts). I don't have any real "pressure" concerns in which case I am free to run either way.
Does anyone know of a reason why I ought not/can not do this?
Another installation question I have has to do with splicing wires: the fixed knot woven wire fencing comes in 200' rolls. Given that I'm going with graduated horizontal wires (13 of them) I won't have a lot of room lower down on the fence to splice. I've ruled out trying to do hand wrapping. Crimps also seem like they could be a challenge, operating the crimping tools in tight spaces. The solution, it seemed, was to use Gripples. One wire manufacturer, Bekaert, even includes Gripples with select rolls of wire (fixed knot being one type). This seemed like a perfect solution, and I'd pretty much had my mind made up on using Gripples, but I just ran across a thread here in which a couple folks said that they found that the Gripples didn't hold. Should I stay away from Gripples (and go with crimps)?
~~~~ ditch ~~~~
O____+____+____O
~~~inner side~~~
