looking for tips on leveling land
   / looking for tips on leveling land #21
</font><font color="blue" class="small">( For what it is worth, in keeping with cajunrider's post on carport.
Most of my equipment is in a large garage. Hand tools seem to mostly get stored in a "pre-fab" shed I placed on a gravel pad of 2B for drainage, and the trimmed the perimeter with ornamental stone to keep the boss happy.
I was looking for something to keep direct sun and the elements off some attachments when I saw these carports "pop-up" at local outdoor business.
Anyway the one I got is 18'X21'- 4" galvanized square box tube bolted together with metal roof. Cost $850.00 installed/built on my lot by a crew in less than two hours. Structure is "pinned" to "relatively" level area. I added some gravel inside (mostly what I had laying around or left over from some customer jobs) for a floor as an experiment.
Well, it has been there for 3 years now and has just been great. I keep my PHD, BB, rake, harrow, roller, tiller, wheelbarrow and small carts in it. It has weathered well and works as intended. I put a small rubbermaid outside storage container in it for fuel containers and other Misc. items.
The way it is built I could "skin" the sides easily with the same metal as my garage, just haven't gotten around to it yet. )</font>
Do you have a link to where these can be purchased? Thanks. Gerard
   / looking for tips on leveling land #22
Could you post some pictures of your carport? I am also considering doing this..
Thanks!
   / looking for tips on leveling land #23
I am not sure if this is what he has but these are the ones I was looking at and they seem to fit his description.
Unfortunately they are updating their website at the moment.
www.carolinacarports.com
These are popped up all over town here (Clarksville, TN) and you go in and pay 10% and then they come build it and you pay the balance. Will probably see one or two around my place this year.
   / looking for tips on leveling land #24
Alan, it says the site is under construction, so I didn't find any pictures, but I think Carolina carports are almost the same as the T-N-T carports like I have.
   / looking for tips on leveling land #25
You have to hold your mouse over the "Main Menu" selection then the menu options will appear. Then you can click on Carports and such.
   / looking for tips on leveling land #26
Dan,
The shed you describe will be fine to hold your BX the way it is. Most prefab sheds that are setup the way you descibe are designed to hold the weight of a vehicle. I wouldnt do it but that is what they say.
Ideally, I would use a laser level to level your base out. My concern would be getting the fresh dirt compacted. How deep are you filling with dirt? If its only a few inches, just use all gravel to level the area out.
I would put the dirt in and rent a vibrating compactor to compress it. Get it semi level and put a couple inches of gravel on top of that so your treated wood isnt laying directly on the dirt. Do your final leveling with the gravel. If youve still got the compactor, run it over the gravel.
Where in MD are you located? If its near Hagerstown, you can use my laser level.
   / looking for tips on leveling land #27
Yep, I missed that. /forums/images/graemlins/frown.gif
   / looking for tips on leveling land #28
Thanks for the links guys. Gerard
   / looking for tips on leveling land #29
Sorry for the late response, was off getting a new utility truck. My carport is in fact a "T-N-T." I tried to get a digital pix last evening, but digital camera is acting up.
The thing is actually pretty straight forward and simplistic, maybe that's why I like it so much. I can "un-pin" it and, if I hook up to it correctly I can slide it around with little trouble. Obviously the trick is in getting an even pull from the hook-up.
A buddy got one after he saw mine and set it up in his back yard. A year later he decided he wanted to move it to his camp. He just made a diagram, dismantled it, loaded it on his trailer and set it up at his camp. Then he got another one for home, larger of course.
If you need me to, I could go out and try to get a phone number off of one of the models.
   / looking for tips on leveling land #30
Tim, I see that Bird has found the link for Gerard, and when I went there they had pix. I think you would be happy with the overall product, I know I was. Hope it works for you guys.
UNUSED WOLVERINE JMR-22-8.5G 1R RIPPER (A54757)
UNUSED WOLVERINE...
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A54814)
2016 Ford F-550...
2013 CAT 950K WHEEL LOADER (A53843)
2013 CAT 950K...
Zero Turn Mower (A55851)
Zero Turn Mower...
2017 PETERBILT 579 DAYCAB (A55745)
2017 PETERBILT 579...
2015 Chrysler 200 Sedan (A55758)
2015 Chrysler 200...
