looking to buy- Kioti v. Branson v. Mahindra v. JD
   / looking to buy- Kioti v. Branson v. Mahindra v. JD #11
One thing I would not like is the 2 speed trans. You said Kioti is weak not ck series. the difference is 300 lbs for FEL. The kioti has better pump flow but your back to the 2 speed trans...
TractorData.com Mahindra Max 26XL tractor information
TractorData.com Kioti CK251 tractor information
compared to what?
300- 400 lbs between the two is something I would call significant, especially when you use apprx 1000 Lbs as the base..... Sounds like a 30-40 % difference to me. I'd call one a lot 'weaker' than the other.
   / looking to buy- Kioti v. Branson v. Mahindra v. JD #12
Had a 35 hp, dk Kioti with loader,4/wd drive,diesel,sold it, bought used Branson 2910i and I must say the Branson's rear-end does not come off ground with heavy load like the Kioti, but the Kioti was good,just seemed to lack the power of Branson after I had operated both. I have a friend who has a Mahindra says he wouldn't own any other. I also own a 1982 18 hp,4wd,diesel Mitsubishi beaver 3 and have had less trouble with it than the other 2 tractors, of course it has no bucket,but it is a work horse. Growing up we used Fords, they are great,but with just 5 acres it doesn't justify the cost. You are going to love what ever tractor you choose, there is nothing better than owning a tractor with a bucket, I put a grapple thumb on mine,I can pick up a piece of tin,or a board. My Branson is down right now,I am replacing the PTO Shaft I sheared off ,got caught in bundle of wire I didn't see while running roto tiller. Learned lesson will use slip clutch.
Thanks for the replies everyone. I had it narrowed down to a Kioti CK2510H and called around and finally found a dealer I liked (that didn't change the price $1700 when I was starting to write a check like the first one did, but that's a different story I will refrain from telling). I drove 100miles away just to look at a tractor and to "just test drive one LS tractor" and ended up buying a LS XJ025H w/ 4ft cutter while I was there. I read enough positive reviews here and read enough good information elsewhere that I was confident I made the right choice for me. It's supposed to be delivered tomorrow. I can't wait.
DT
2017 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2017 Ford F-150...
Hose Reel (A55787)
Hose Reel (A55787)
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2014 International Bucket (A55973)
2014 International...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A55973)
2015 SkyJack SJ86T...
2014 Dodge Charger Sedan (A55973)
2014 Dodge Charger...
