Looking to buy Mahindra 5565 or TYM T554 or Branson 5220c - Not sure direction
   / Looking to buy Mahindra 5565 or TYM T554 or Branson 5220c - Not sure direction
I have made my decision. Going with a Mahindra 2565 and have it set to take delivery of it next weekend. I will give a breakdown as to my decision.
Branson - I gave the 4220c and the 5220c a very hard look. Very limited dealer network in east Texas. I like both tractors. Very well built and heavy for their size. Not any difference in the the two that I could distinguish except the 4220 is aspirated and the 5220 has the turbo increasing the horse power by 5. Price was also very good in my mind at $26,400 and $29,000 for the two. Price and beefiness of the Branson kept pulling me back but in the end the limited dealer network is what killed the deal for me.
TYM - basically the same as the Mahindra 2555. Even less of a presence than Branson where I'm at so decided no on the TYM.
On the other hand, I seriously considered the Mahindra 2555. The Mahindra 2555 was priced at $30,400 and seemed like a good fit as there are several full service Mahindra dealers within 60 miles of me. Then I looked at the 2565 and was trying to figure out the $2800 cost difference as one dealer told me they were the same machine but the 2565 had bigger tires. I was finally able to do a side by side comparison of the two and I was shocked to visually see the difference in the axle size of both. The 2565 is a much beefier tractor than the 2555. No comparison when it came to axle sizes. Adding the larger tires the 2565 will be considerably heavier. Also, the 2565 has the Cat II hitch over the 2555 Cat I hitch and it has telescoping legs. The interior also had a few difference I liked as well. The only thing I'm unsure about is that the FEL stick is a little far up and one basically has to lean forward to use it.....or at least I do. I am trying to find out from the dealer if there is any type of adapter to move the stick a little further back....he's checking into it. Has anyone else experienced this?
Anyway, my L3800 Kubota is for sell! :shocked:
   / Looking to buy Mahindra 5565 or TYM T554 or Branson 5220c - Not sure direction #22
I have made my decision. Going with a Mahindra 2565 and have it set to take delivery of it next weekend. I will give a breakdown as to my decision. Branson - I gave the 4220c and the 5220c a very hard look. Very limited dealer network in east Texas. I like both tractors. Very well built and heavy for their size. Not any difference in the the two that I could distinguish except the 4220 is aspirated and the 5220 has the turbo increasing the horse power by 5. Price was also very good in my mind at $26,400 and $29,000 for the two. Price and beefiness of the Branson kept pulling me back but in the end the limited dealer network is what killed the deal for me. TYM - basically the same as the Mahindra 2555. Even less of a presence than Branson where I'm at so decided no on the TYM. On the other hand, I seriously considered the Mahindra 2555. The Mahindra 2555 was priced at $30,400 and seemed like a good fit as there are several full service Mahindra dealers within 60 miles of me. Then I looked at the 2565 and was trying to figure out the $2800 cost difference as one dealer told me they were the same machine but the 2565 had bigger tires. I was finally able to do a side by side comparison of the two and I was shocked to visually see the difference in the axle size of both. The 2565 is a much beefier tractor than the 2555. No comparison when it came to axle sizes. Adding the larger tires the 2565 will be considerably heavier. Also, the 2565 has the Cat II hitch over the 2555 Cat I hitch and it has telescoping legs. The interior also had a few difference I liked as well. The only thing I'm unsure about is that the FEL stick is a little far up and one basically has to lean forward to use it.....or at least I do. I am trying to find out from the dealer if there is any type of adapter to move the stick a little further back....he's checking into it. Has anyone else experienced this? Anyway, my L3800 Kubota is for sell! :shocked:
The 2565 sounds similar to the TYM T654. They recently added it to the web sight. What was the price on the 2565. Was it $2,800 above the 2555. Making it $33,200. If it was that's not bad for a 65 hp tractor. Mahindra lists mfg retail on their web sight over $38,000.
Yes paying 33,200$ for the 2565.
The TYM T654 apparently has a lot more built into than the 2565. First the engine produces almost 12 PTO HP more, I have heard good things about the Deutz engine. It has 3 RPM PTO speeds, more lift, dual remotes and quite a bit heavier. It probably cost the same as the 2565 but I haven't seen one in person.
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A56435)
Neckover GL24-2-7K...
Wheel Dolly (A59076)
2004 PETERBILT 379 (A58214)
2004 PETERBILT 379...
1992 Norris Long Basket Trailer (A55973)
1992 Norris Long...
New/Unused CFG Industrial NT20-CZ Mini Excavator (A57453)
New/Unused CFG...
Hays LT-1 Tender (A56435)
Hays LT-1 Tender...
