Looking to buy new trailer - need some advice
   / Looking to buy new trailer - need some advice #1
redtailfarm
MA
Kubota L39/GR2120/L4240
I have 2 pieces of equipment to haul. A kubota L39 and bobcat excavator E45. The bobcat is 10245lbs. Neither gets moved too often but I like to have it in the event I get some side work or if repair is ever needed.
I am considering a gravity tilt trailer style. I have seen PJ, Load Trail, Downeaster(which I learned are no longer being made) and some others.
Question - Is a full tilt better than split tilt? I do prefer flat deck, no outside channel.
Would appreciate the good/bad/ugly.
   / Looking to buy new trailer - need some advice #2
I've always wanted a split tilt so I could drag all my chains and binders to the front and not have to worry about them rolling/flying off. Also nice if you want to haul an extra bucket, attachment or ATV that can't be unloaded along with the tractor or excavator in one shot.
   / Looking to buy new trailer - need some advice #3
I have an H&H full tilt because I sometimes need to use a winch, which is a problem with a non-tilting section. I have power up & down so that has different needs than a gravity, such as if I work alone it is almost mandatory to have remote tilt controls and winch controls. It, in my opinion, is too dangerous to load a tractor, for example, then lock the brakes on the incline and climb off to lower the deck.
Tilt trailers are not very handy for hauling multiple items in my experience.
   / Looking to buy new trailer - need some advice #4
Question - Is a full tilt better than split tilt? That depends on what you are hauling. I do prefer flat deck, no outside channel.
Gooseneck or tongue pull?
Low deck or deckover?
I like this one, but think that I want a deckover.
12-19-11 011 (Medium).jpg 12-19-11 014 (Medium).jpg 12-19-11 028 (Medium).jpg 12-19-11 041 (Medium).jpg 1227 (Large).jpg
Check: Kaufman Trailers Utility, Gooseneck, Equipment, Car, and Dump Trailers
   / Looking to buy new trailer - need some advice #5
we have both a gravity tilt, a deckover, and a "normal" car trailer they all have their advantages i like being able flip to a lever, drive onto the trailer, an when i get off have the trailer level. it doesn't work to haul more than one thing or a larger truck/tractor. the deckover in nice because it is so big, but it has a higher center of gravity and it is heavier/larger. the care trailer is in between i don't like the slide in ramps and having to block the rear end of the trailer to drive something heavy on it.
20 ft. Shipping Container (A53117)
20 ft. Shipping...
2012 ford f550 service truck (A52377)
2012 ford f550...
40ft 2-Door Shipping Container (A55851)
40ft 2-Door...
TANK MANIFOLD (A55745)
2014 Ford Taurus AWD Sedan (A55853)
2014 Ford Taurus...
2016 Ford Explorer AWD SUV (A54815)
2016 Ford Explorer...
