Looking to buy, suggestions wanted
   / Looking to buy, suggestions wanted #1
seths
I am looking to buy a mower to cut 2 properties, one 4 acre and one 2 acre. I will be splitting the cost with the 2 acre property, so I can spend a little extra since I won't be putting up all the cash. Both of our properties are flat and only have a house and a few trees to work around. That being said, we are looking for a mower that is faster than our current one with a larger cutting radius. What are your suggestions for a tractor to do such work? Again, it will only be used to cut these 2 properties so I don't want to spend too much, but I would still like something that is reliable and fast. Any help would be appreciated
   / Looking to buy, suggestions wanted #2
What do you have to tow it around with would be the first question. If you went with a tractor you may need a heavier truck to pull it, could you get by with a zero turn mower or something with a 5' or 6' deck?
The two properties are very close to each other (2 blocks). I would just drive it down the street so towing it around is not an obstacle
   / Looking to buy, suggestions wanted #4
<font color="blue"> so I don't want to spend too much, but I would still like something that is reliable and fast. </font>
seths
Not spending too much means? /forums/images/graemlins/confused.gif
A <font color="orange"> Kubota </font> ZD18 or 21 would fit the reliable and fast part of the above statement.
Click Here
With a 60" mower, 4 acres could be cut in less than 2 hours.
<font color="orange"> Kubota </font>also offers a gas version of the above models.
   / Looking to buy, suggestions wanted #5
<font color="red"> "...looking for a mower that is faster than our current one with a larger cutting radius." </font>
Welcome to TBN Seths. What do you have now? Do you plan on doing anything with the tractor besides mowing? If so what? If it is just mowing I would definitely go with Ronjhall's suggestion or a similar Zero turn mower if the ground is not too rough. /forums/images/graemlins/smile.gif
   / Looking to buy, suggestions wanted #6
Don
I forgot about the rough ride if ground is not smooth. When I purchased my front mount mower, dealers delivered several different types of mowers to try. The ZTR's was the worst riding for me.
   / Looking to buy, suggestions wanted #7
if you plan on just mowing, I would sugest some sort of ZTR mower. They really get the mowing job done fast,,
If you plan on plowing, fixing the road, moving dirt, then you need to consider a tractor. virg
<font color="red">Not spending too much means? </font>
Not spending too much relates to buying something more than I need. There are diminishing returns as price goes up, performance doesn't go up quite as much. It would be like purchasing a ferrari when a corvette is all you really need. (read: it is still expensive, but much less expensive than the ferrari)
To answer the other questions, the yards are both relatively smooth, certainly not hilly and it will be used ONLY for cutting.
   / Looking to buy, suggestions wanted #9
OK, Just the facts. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
How much of your money can we spend?
   / Looking to buy, suggestions wanted #10
Like the others said. What are you mowing with now? What are you wanting the total budget to be? And are both of the property owners willing to buy/drive a tractor? Also.. what is the time frame for the cut? ( how long do you want to set on the mower to make the grass shorter? )
Soundguy
2011 Kubota L3200 (A50120)
2011 Kubota L3200...
Kinze 600 Grain Cart (A52349)
Kinze 600 Grain...
2008 Wilson Hopper Bottom Trailer (A50514)
2008 Wilson Hopper...
2000 Mercedes-Benz S-Class Sedan (A50324)
2000 Mercedes-Benz...
Lot (3) Rolls of Barbed Wire (A50515)
Lot (3) Rolls of...
2013 Toyota Prius Hatchback (A50324)
2013 Toyota Prius...
