Looking to learn about tractor with bush hog
   / Looking to learn about tractor with bush hog #11
Re: New member ?.. Looking to learn about tractor with bush hog
Good advice from some knowledgeable people. Take the time to look around at your property and think of ALL the tasks you wi to do, make a list and many on here can help you narrow your search. There are enough makes and models available to pull a bush hog as to boggle the mind. My brother has several tractors up to 72HP, but when bush hogging often hops on one of his old Ford 600's and a 5' cutter. I prefer a bigger tractor, but we both get the job done. Now throw in other tasks and we have to get on one of the bigger tractors with a FEL etc.
   / Looking to learn about tractor with bush hog #12
We have a bit over 42 acres (brother in law and myself) and the first year of ownership, we mowed the whole thing with a JD 750 2 WD with a a 4 foot bushhog. We could have used a much larger tractor as it was highly overgrown with weeds, saplings and tall grass and many places were wet from spring feed areas that limited access with the 2 wd tractor with turf tires. We later added a 4 WD 50 HP tractor with 6 foot hog and really reduced the time mowing plus were able to access the swampy areas. It is all relative as to how long you have to do the work. We were both working still at the time and only had a couple days per week to work on it but it eventually got the whole 42 acres done. Years later now we have sold the 750, bought a New Holland 2310, an LS P7010 and a Kubota B26 TLB. The B26 gets more hours than the other two combined. We have about 30 cows on it now and they pretty well keep it mowed for us so it is just moving hay, digging rocks, cleaning ditches etc for maintenance other than the yearly garden prep. We could get by with just the NH for the pastures but the TLB is needed for maintenance of ditches, digging holes to bury dead animals, plant trees etc. Since everything is paid for, it doesn't cost anything to have the rarely used stuff just sit under a shed till needed AND they are all handy to have at times, like when BIL got his New Holland buried in a spring feed area, the LS came to the rescue. I don't know if the Kubota would have pulled him out or not, maybe!! That is the beauty of having multiple tractors. Prior to getting our second tractor, I had to use my 4 WD truck a couple of times to pull the JD 750 out of the mud which we were just lucky to have enough chains to get the truck on some firm ground.
For 20 acres including some pasture and plans for a garden (likely need a tiller to prep it) I would look for at least a 40 engine HP tractor which can pull a 6 foot bushhog, a 72" tiller or 6-7 foot disc. Get it with Ag R1 type tires if you have any notion of ever working in any muddy conditions as the R4 industrial tires don't do well in mud which is one reason I had to pull the NH out of the bog as it has industrial tires. They do well on dry ground and have more rubber to not leave as much track on a lawn but don't do well at ground engaging tasks. I hear they work better than R1's with chains on ice but since I don't do snow removal, I cant speak to that.
Also a front end loader is really nice to have and to get good use of one, you need 4 WD on your tractor. Larger HP (like 90HP +) tractor can perform ok without 4 WD but it is a necessity on a CUT or smaller old iron tractor. I was rather skeptical of needing an FEL when I bought my first one (Yanmar 4220D) as I spent 25 years on a farm and never had 4 WD or a FEL, but after getting the first one and seeing what they can do, all others have an FEL AND 4 WD even my 70 HP utility tractor needs 4 WD to perform any ground engaging tasks.
   / Looking to learn about tractor with bush hog #13
Another thing, there is no such thing as a tractor that will do everything well. Most tractors as equipped do one thing well and the rest "good enough". As a for instance, if your tractor is equipped for mowing, whether it has a belly mower or rear finish mower, with R 4 tires or turfs it will mow great, leave little compaction or grass damage but be only marginal for other tasks. A tractor with R1 Ag tires will mow but likely to leave lug marks on your yard but it will have excellent traction in mud and dirt for ground engaging work. You must decide how you plan to use it most and equip it for that task and then live with the marginal ability to do the other stuff.
For this reason, we don't have any tractors to do yard mowing, we use bush hogs to mow the pastures. We have lawn mowers to mow the yard and they do much better than any tractor would do and do it much faster. Tractors are only good for mowing straight aways with very few obstacles to interfere or have to mow around where as I can use my ZTR to mow around trees and bushes with hardly a slow down.
That is my other advice, use a tractor for tractor work and get a lawnmower for lawn care. I have a neighbor who mows about a 10 acre meadow (no obstacles) with his ZTR mower even though he has a nice Kubota tractor. He mows with a commercial duty ZTR at about 10 MPH which is much faster than his tractor would mow and it looks GOOD when he finishes.
   / Looking to learn about tractor with bush hog #14
Welcome from just down the road. As mentioned there are lots of options out there. A tractor in the 30 to 45 hp range seems to be a good catch-all, and your mower size will depend on your hp. Once you buy one and use it a while, you may wish you would have bought bigger.
   / Looking to learn about tractor with bush hog #15
When I bought my second tractor, I was looking for 50 HP tractors and had a figure in mind of around $35K with cab. When I found my 70 HP LS P 7010C for $35K, I figured why not, never such thing as too much HP right. Well that is somewhat true but I found many areas where it is just too big to get into and ended up buying a B26 Kubota TLB for those small areas. I still use the LS for large jobs that are very infrequent now and the B26 is my go to tractor for most tasks as it is easier to get on and off of(one step rather than 3/top of fender less than shoulder high rather than higher than my head), smaller so more maneuverable and easier to see what I am doing with the FEL.
I don't think I would get rid of either tractor as they are both needed at times, but just be aware that TOO LARGE is easy to do but so is TOO SMALL. I think that of the two choices, TOO SMALL is better than too large. With too small, the task usually can still be done, it just takes longer whereas with too large, you may not be able to even do the task.
   / Looking to learn about tractor with bush hog #16
Welcome to TractorByNet!
We moved your thread to the Buying/Pricing/Comparisons forum. :)
2015 Chevrolet Silverado 3500HD 4x4 Crew Cab Service Truck (A53422)
2015 Chevrolet...
2012 Ford F-550 Crew Cab Truck (A54814)
2012 Ford F-550...
2019 MACK PINNACLE P164T DAYCAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
UNUSED DIGGIT 6'5"-10 DRAWER, 2 CABINET WORK BENCH (A54757)
UNUSED DIGGIT...
2018 FORD EXPEDITION (A51406)
2018 FORD...
2013 Mitsubishi Fuso FEC72W 18ft Dovetail Flatbed Truck (A51692)
2013 Mitsubishi...
