Looped tiedown chains?
   / Looped tiedown chains? #11
I think this is because the DOT wants the load to be shared by each "leg" of the chain. If you think of it this way, a large object sitting on a trailer starts with a chain connected one side of the trailer, then passes over the load, and is connected on the other side of the trailer with a binder somewhere in there to take out the slack. Each leg of the chain only sees half of the load in theory.
I believe that if you fix the binder to a trailer, and connect it to a load with a short length of chain, that they only give you credit for 1/2 of the WLL of the chain; which is total BS. Someone else can jump in here and cite the FMSCA if they want to.
2016 MACK CXU613 MID-ROOF SLEEPER (A55745)
2016 MACK CXU613...
Brown Metal Roof Panels (A55758)
Brown Metal Roof...
Black Tip Steer Horn (A55853)
Black Tip Steer...
500 BBL WHEELED FRAC TANK (A55745)
500 BBL WHEELED...
2018 John Deere 30G Mini Excavator (A52377)
2018 John Deere...
