Loss of Power to Diverter Valve Switch
   / Loss of Power to Diverter Valve Switch #1
hiflyer
Palm City,FL
JD 4310 eHydro, Mid/Rear PTO,T'N'T, 3rd SCV
Would appreciate if anyone could direct me to What # Position the Relay for the Diverter Valve Switch is located in the fuse panel. While switching between using the loader & the T'N'T on Saturday the Diverter Switch lost power. 4310, eHydro, 430 loader. Called Service @ my local dealer, and they are looking ,but no answer yet. Not sure if there is a designated position for this relay, since the diverter switch is a factory option, but if so would like to check it out , before pulling all the relays for testing. Any assistance is Greatly Appreciated, bugs me when things aren't work'n & I got stuff to do.
Lloyd
   / Loss of Power to Diverter Valve Switch #2
Lloyd, glad that you were able to get this problem fixed. Thanks for the email and the nice picture.
Smitty, Simple enough to fix, but finding the glitch was the twist....
For someone elses future reference, the relay is labeled K17 in the diagram, located behind the Joystick Lock Out ( Relay has a tab and attached under the top nut/bolt.) Requires removal of the seat, and plastic seat pan to gain access. Power for the switch is from a pigtail on the left side of the back of the fuse panel, then usually run under the tractor on the right side along the hydraulics. There is also a diode in the harness that is a male/female plug in , and because of the harness length should be located on the underside where the wires start up to the switch. In my case no faulty component, but the power wire was stretched with out breaking the insulation, but no continuity.
JOHN DEERE 5115M TRACTOR (A51243)
JOHN DEERE 5115M...
2007 Hyundai Sonata GLS Sedan (A51694)
2007 Hyundai...
2018 JCB 507-42 7,000lbs Rough Terrain Telehandler (A53421)
2018 JCB 507-42...
FRONT END LOADER BUCKET (A53843)
FRONT END LOADER...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
1995 POLAR TANK TRAILER TRANSPORT TRAILER (A55745)
1995 POLAR TANK...
