Lost 1st & 3rd on NAA
   / Lost 1st & 3rd on NAA #1
NAAsty
I used the NAA last weekend for some light blade work, all was fine. Hooked up the Bush Hog this weekend, and I can't get the tractor into first or third gears. Adjusted the clutch... made no difference. How bad is it?
   / Lost 1st & 3rd on NAA #2
You should post that out on ytmag, more of a vintage focus than TBN, which is mostly newer stuff.
-P
   / Lost 1st & 3rd on NAA #3
Pull your tranny top cover ( do it slowly.. and watch out not to loose any ball/detent springs which may be loose.
Inspect the shifter guid pattern unde rhte top cover.. also look at the shifter rails, and shifter forks.. sometimes the set screws in those forks DO come loose.
If it tries to stall with the clutch out.. it may be stuck in two gears.. also a problem with shifter forks.. etc..
The bottom of your shifter may also be worn in addition to everything else.
Pop it open and take a looksee.. gonne be hard to do anything else till you look. Post your findings on the ytmag.com 9n/2n/8n board... I'm a regular over there.. and there are alot of guru's there to offer help.
Soundguy
Thanks Soundguy. I did post to YTMAG, but it was on Saturday night, probably not a high traffic time.
I figured I'd have to pull the top, but I wouldn't have done it quite as cautiously as you warned. I'll heed the advice.
Thanks.
2014 CATERPILLAR CT6605 SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
2023 PETERBILT 579 TANDEM AXLE SLEEPER (A52576)
2023 PETERBILT 579...
2020 JOHN DEERE 331G SKID STEER (A51246)
2020 JOHN DEERE...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
2013 MACK GU713 (INOPERABLE) (A52472)
2013 MACK GU713...
2007 INTERNATIONAL MA025 (INOPERABLE) (A52472)
2007 INTERNATIONAL...
