Lost 3 of my 4 guages this morning???
   / Lost 3 of my 4 guages this morning??? #1
Momboy007
San Diego
Jinma 304
Hello All,
I started up the tractor (2005 Jinma 304) today to brush hog after about 2 Months of sitting, had a few issues
1. When I started the motor, all guages worked just fine, then all of the sudden, the fuel guage, temperature guage and oil pressure all went to zero, only the ampmeter continued working, any clues?
2. The lower radiator hose started leaking and will need replaced, does anyone know a part number to use? or who to get one from.
Oh Yea, this is a one piece guage with all the guages built in
I guess that is all I can think of now, thanks in advance for any help you give
Rick
   / Lost 3 of my 4 guages this morning??? #2
The ammeter is the only one of those that isn't fused. I would check the fuse panel.
   / Lost 3 of my 4 guages this morning??? #4
Fuse or ground is most likely your gauge issue.
For a hose just take it to a parts store. You can find a hose to cut down and make work. I would replace the top hose also.
Chris
Chris, I agree, I will replace both hoses, and I think my tractor is the same as a 284, as far as wiring is concerned, thanks for the schematic and ideas
Rick
   / Lost 3 of my 4 guages this morning??? #6
Chris
I second on both recommendations
   / Lost 3 of my 4 guages this morning??? #7
x3. Instrumentation (less ammeter) are protected by the ACC fuse. If that doesn't fix the problem, open and inspect the multi-pin connectors behind the cluster. Sometimes a good cleaning and/or reseating will restore the circuit. If not, the problem is likely internal to the cluster itself. Is yours rectangular or round, and how many pigtail connectors does it have?
//greg//
Hello All,
The guages are back up and running, It turns out is was a fuse, thanks for all your help, could not have done this without you all.
When I replace my radiator hoses, is there a special anti-freeze to use with a Diesel motor?
Thanks all
Rick
AFFORDABLE, what is a upper and lower Radiator hose going to set me back?
   / Lost 3 of my 4 guages this morning??? #10
SCA-type anti-freeze is needed for wet-sleeved diesels, conventional anti-freeze is ok for dry-sleeved. Given that there's not much difference in price, I hedge all bets and use SCA-type in all my diesels.
//greg//
2018 Gatormade 20+5 Gooseneck Trailer (A53473)
2018 Gatormade...
2012 Ford E-150 Passenger Van (A51692)
2012 Ford E-150...
Toro Workman 200 Sprayer Cart (A50324)
Toro Workman 200...
2022 Big Tex 22GN-35BK+5MR 40ft 12 Ton T/A Gooseneck Equipment Trailer (A51692)
2022 Big Tex...
2013 Nissan Rogue SUV (A51694)
2013 Nissan Rogue...
UNUSED Yellow Outdoor Patio Fabric Screen (A53117)
UNUSED Yellow...
