lost drive on a 6640 powerstar sle 16X16 powershift
   / lost drive on a 6640 powerstar sle 16X16 powershift #1
rcbatti500
6640 sle
I lost drive on a 6640 powerstar sle 16X16 powershift earlier this summer.
(blue roof pre 98 model, about 6500h )
no fault coades, only gearbox oil light when in gear and releasing clutch. I searched the internet and found the gasket 82008709 might be broken (witch it was) so i replaced it with all the o rings on the side plate .Today when starting up after replacement i had very little drive for a few seconds( manedged to crawl a few meters forward on flat surface in lowest gear but no proper cluth engagement),but the drive decreased to zero and the tractor is now behaveing like before.
when I run the motor at high rpm with gears engaged and switch from 1-2 , 3-4, 5-6, 7-8 it makes no sound but 2-3 and 6-7 makes an clutching sound.
At allmost full rpm and some reverse gears the light might come off but still no drive.
Where do I measure the pressure for c1, c2, c3, c4 and what is the proper pressure?
Unused 2025 CFG Industrial QK16R Mini Excavator (A59228)
Unused 2025 CFG...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
TAKEUCHI TL8 SKID STEER (A60429)
TAKEUCHI TL8 SKID...
2005 MACK TRI AXLE DUMP TRUCK (A52707)
2005 MACK TRI AXLE...
2008 Ford F-250 Lariat 4X4 - 303,424 miles - 6.4L Powerstroke -Automatic (A61306)
2008 Ford F-250...
2013 Felling Trailers T/A Side Dump Flatbed Trailer (A56857)
2013 Felling...
