lost injection pump gear mesh
   / lost injection pump gear mesh
I have read that with some other pumps, after being rebuilt, they are set and somehow "locked" at No1TDC,
but mine is not like that. There is no way to set the pump in any particular position, at least not without seeing timing marks inside it. The pump shaft can only mount to gear one way, so had to turn pump shaft to align to gear. Only other possibility would have been to turn gear to match pump and I know that's not correct.
if you turned pump to match gear you messed up. you need to pull front cover and line up timing marks and then have pump set again then install pump
   / lost injection pump gear mesh #12
about the only thing you can do now is try to start it, if it starts you got lucky, if it don't you will have to get it timed
   / lost injection pump gear mesh #13
Did you get this worked out?
2016 CATERPILLAR TL642C TELESCOPIC FORKLIFT (A51242)
2016 CATERPILLAR...
71069 (A49346)
71069 (A49346)
1973 CATERPILLAR 988 LOADER (A51222)
1973 CATERPILLAR...
40ft Shipping Container (A49461)
40ft Shipping...
2017 Caterpillar 326FL Hydraulic Excavator (A50322)
2017 Caterpillar...
2015 KC TRAILER 130 BBL STEEL VACUUM (A50854)
2015 KC TRAILER...
