Low Hydraulic Pressure???
   / Low Hydraulic Pressure??? #11
If the 3pt relief pressure is 2489 psi, then adjust the FEL relief the same.
To set the relief pressure, compute the engine rpm necessary for a 10 GPM hyd flow, and then set the engine speed.
Then adjust the FEL relief for 2489 psi.
If you can do this, your hyd system is OK.
   / Low Hydraulic Pressure??? #12
JJ,
Am I the only one with problems with the videos.....??
I get "Cirtex Hosting" .....Account suspended
I calculated the rpm for the specified flow and made the adjustment.
Afterward my idle pressure increased 300 psi from where it was.
The pressure does still fluctuate 200 psi with engine rpm however. Is this something I should be concerned about?
Thank you very much for the help with this project, I really appreciate your knowledgeable assistance.
Casey
   / Low Hydraulic Pressure??? #14
JJ,
I tried to link your video, and it says account suspended.
   / Low Hydraulic Pressure??? #15
I'll have to see if I can download it to my photobucket account instead....at least it's not me :confused2:
2006 FREIGHTLINER CL120 DAY CAB (A53426)
2006 FREIGHTLINER...
Ford Tractor (A50120)
1262 (A50490)
1262 (A50490)
2019 MACK P164T DAYCAB ROAD TRACTOR (A51406)
2019 MACK P164T...
