Oil & Fuel Low oil pressure? No, bad sender!
   / Low oil pressure? No, bad sender!
One more comment on the matchup of U.S. and Yanmar/British 1/8" pipe thread: I tried threading a half-dozen different US-standard brass and iron-pipe fittings into the Yanmar block, which has British Standard pipe thread. Some would thread in several turns by hand but some of the brass fittings wouldn't catch the first thread. Completely random.
It appears that the new and old oil senders, which have the proper Yanmar/British Standard/Japanese-Automotive pipe thread, have a greater taper and are smaller diameter for the first few threads compared to US fittings which may or may not be too large diameter to catch the first thread. For the several brass adapters that I threaded in and tightened, their threads were not distorted when I removed them so apparently that overall taper is the only difference.
Note these comments are all about the the oil pressure sender. Yanmar used Metric threads for the temperature sender.
Toro Workman MDX Utility Cart (A51694)
Toro Workman MDX...
2019 Ford F550 Bucket Truck - Powerstroke Diesel - Auto Trans - 4X4 - 72258 miles -Altec AT40G Boom (A53472)
2019 Ford F550...
2019 CATERPILLAR D6T LGP HI-TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
2015 Ford F-550 4x4 Knapheide Service Truck (A51692)
2015 Ford F-550...
2025 New/Unused Wolverine Auger Drive and Bit (A51573)
2025 New/Unused...
LMC LOT NUMBER 142 (A53084)
LMC LOT NUMBER 142...
