Oil & Fuel Low sulfur diesel ?
   / Low sulfur diesel ? #1
benelli
Louisiana
Today I heard someone say you were not suppose to use low sulfur diesel in new model Kubota's. I explained that was incorrect. Has anyone else heard this as well?
   / Low sulfur diesel ? #2
It is mandatory in North America. That's what the owner's manual says.
   / Low sulfur diesel ? #3
Benelli,
The only proviso is with the engine oil used.
If you are using low sulfur fuel, use API rated CF-4 or CG-4 engine oil.
If you use high sulfur fuel and these oils, cut the drain interval in half (100 hours)
I can't imagine anywhere in the US that does not use low sulfur fuel - maybe in developing countries they use high sulfur fuel so that is why the manual specifies something different.
I think the guy was actually refering to diesel made a few years ago vs today's lower sulfur content to meet stricter emissons.
   / Low sulfur diesel ? #5
Except the OP said "newer model Kubotas".
ULSD is fine, only issues are with injector lubrication and you can easily add a little fuel conditioner to improve that.
2007 Ford Ranger Pickup Truck (A51692)
2007 Ford Ranger...
A1 Terminator 3pt Blower w/ 60 Gal Tank (A50120)
A1 Terminator 3pt...
John Deere 5203 Tractor (RIDE AND DRIVE) (A50774)
John Deere 5203...
Mini Excavator Attachment Set (A50121)
Mini Excavator...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2020 Kubota RTV-X1100CW-A (A47384)
2020 Kubota...
