low temp electric space heater
   / low temp electric space heater #1
klink
Bronze Member
Ohio
Ford 660,JD 4110 Hydro - JD 670 gear - 48 Farmall Cub - 51 Farmall H - John Deere 50 - JD X540 JD X580 AC 917 WH 81 Cub Cadet 1541 & 70
I'm trying to heat a porch enclosure and keep the temp down to 50 degrees. I purchased an Eden Pure electric heater, and it works great. But I can't get it to stay below 62 degrees, even at its lowest setting. Do any of you know of an electric heater that will maintain the temp down to 50 degrees? This is to save energy in an area not used much.
   / low temp electric space heater #2
you can put it on a timer and program it to go on and off a few times a day.
   / low temp electric space heater #3
I have a couple of heaters with digital thermostats. Anytime the units are turned off the setting has to be reset.
   / low temp electric space heater #4
Thermo cube plug in thermostat. Not adjustable but they have plugs with different ranges. I use a 35 to 45 degree in my chicken coop. Works good and not expensive. Less than $20. Check voltage ,amps etc. of course.
2007 Freightliner School Bus (RUNS) (TITLE) (A50774)
2007 Freightliner...
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
(3) 8' High Pole Swinging Gates (A50515)
(3) 8' High Pole...
2020 CATERPILLAR 326 EXCAVATOR (A51242)
2020 CATERPILLAR...
2012 Porsche Panamera Hatchback (A50324)
2012 Porsche...
LEE G550 MOTOR GRADER (A51242)
LEE G550 MOTOR...
