Low water pressure at barn
   / Low water pressure at barn #1
fibrostic
I have a barn that is around 400 ft from my house, it pulls of the same well pump that the house does. I want to add a water system to the arena, but the pressure is to low in the barn. Can i add an expansion tank and some kind of pump? What can I add in the barn to increase the pressure?
Would something like this do the trick?
[ame]http://www.amazon.com/Horsepower-Shallow-Booster-Stainless-Hardened/dp/B005TRUWNY/ref=pd_sim_sbs_hi_5[/ame]
So basically my existing line would act as the "well" and supply this pump with the water for it to repressurize?
   / Low water pressure at barn #2
1)booster pump
2)pressure tank
3)run new (bigger) water line
I guess i should have specified that running another/bigger line is probably a long term solution, but not the one i am looking for as it would require a little more than i was hoping to put into it. Really i am trying to figure how to set up a tank and a pump correctly, or what type to get.
   / Low water pressure at barn #4
Amazon.com: 1 Horsepower Shallow Well Booster Pump with Stainless Steel Housing and Volute and 6.3 Gallon Hardened Steel Alloy Tank; Maximum well depth: 26 ft.: Home Improvement
Why is the pressure low at the barn?
If you are using a frost free hydrant, a lot of times the plunger shaft gets out of adjustment which restricts the flow, making you think the pressure is low when it is not.
   / Low water pressure at barn #5
It is a matter of supply and demand. Add a large non-pressurized tank at the barn to collect the low-pressure/low-volume water from your existing system (maybe fill-up over night). Then add a booster pump to the outlet of the big tank. Lots of higher pressure/higher volume water until you drain the collection tank. :)
Start all over for the next cycle.
   / Low water pressure at barn #6
1- What is the water PRESSURE at the house?
2- What is the water PRESSURE at the barn?
3- Exactly what is the fixture that has poor performance? (Picture please)
4- What size is the 400' pipe, of what material and how old is it? If you
do not know measure the OD of the pipe.
5-Was the pressure OK at one time or has it always been bad?
6- What is the elevation difference (up or down too) between the house and the barn.
HERE is a nice lil gauge w/ tattle-tale. (No need for tattle tale but in the future it can be nice)
   / Low water pressure at barn #7
What is your static water pressure? If your low pressure is because of a small pipe size you may have good pressure but a lot of loss to friction. I have seen a bladder tank installed to give good pressure for the capacity of the tank. Say if your static pressure was 50#PSI but when you open the valve it drops to 5#PSI you could install a 20 gallon bladder tank and have 10 gallons or so before your pressure would start to drop off. Just a thought.
   / Low water pressure at barn #8
X-2 This is your first place to start, gather this info and it will let you find the best solution.
   / Low water pressure at barn #9
2- What is the water PRESSURE at the barn? At zero flow.
6- What is the elevation difference (up or down too) between the house and the barn. This and # 1, 2 must agree
....:thumbsup:
   / Low water pressure at barn #10
I would get complaints on low water pressure and almost everytime the pressure guage readings were nearly identical at all locations.
What I found most of the complaints were really about volume... unless there was a significant vertical varition from high to low.
Volume is often a restriction problem... something in the line or length of the run.
2011 SOUTHWEST  GOOSENECK (A48992)
2011 SOUTHWEST...
2005 Great Dane Trailer, VIN # 1GRAA96265S700587 (A48836)
2005 Great Dane...
2007 Ford Escape AWD SUV (A48082)
2007 Ford Escape...
SHED W/CONTENTS (A48992)
SHED W/CONTENTS...
John Deere 850J Dozer (A47371)
John Deere 850J...
9055 (A48836)
9055 (A48836)
