I have read many threads and responses on the issue with LS Tractors randomly shutting off. I have had the problem many times as well. It seems like one of the options is to hot wire the Fuel shut off solenoid. Mine will start like others but engaging PTO or attempting forward or reverse will shut it down like others have posted. My problem is I cannot find the fuel shut off solenoid on any parts list or images for the J2030H. I assumed I would find a wire attached to some portion of the fuel line/ filter/ injects /pump but don't see any. Can anyone send an image of where the fuel shut off solenoid is located? The engine is a Mitsubishi S3L2-20. Basically once it shuts down you turn the ignition off and wait some period of time from 5 minutes to an hour and everything is fine. Now sometimes after trying to start it for the first time for the day it has the same problem. Starts fine but then cannot move forward or reverse but after several attempts of shutting off the ignition and waiting it will move again. Any help on this would be much appreciated.
Phil
Phil
