ls tractor hst vs Fully Synchronized trans
   / ls tractor hst vs Fully Synchronized trans #1
Peter 315
Super Member
NH
Kubota L3800 HST Kubota L47 TLB
Looking at LS tractors XR4155 , What the advantages of the HST VS 16x16 trans ?
   / ls tractor hst vs Fully Synchronized trans #2
HST=clutchless forward and reverse motion. "infinite" speeds, can be driven by anyone with a pulse.
16x16=cool running for long periods of time, low noise under heavy load, lower initial cost.
See any thread with 'HST vs. Shuttle' in it.
   / ls tractor hst vs Fully Synchronized trans #3
Most people with HST do repetitive forward and backward loader work, gravel, dirt, snow plowing, etc. Gear tractors you usually see doing a lot of farm work like pulling a bottom plow, rototiller, and other ground engagement work. Either will work for you. Just depends on how much you like to shift and use the clutch. I owned and / or ran gear tractors all my life until I got my first HST in 2004. I've never gone back to a gear tractor for all the work I do with it. Just a matter of preference.
   / ls tractor hst vs Fully Synchronized trans #4
I have the shuttle xr4155 I’ve used it quite a bit for loader work and it isn’t that bad at all. I also do a lot of bush hogging in the summer sometimes on pretty hilly terrain which is why i went with the shuttle. No way i would want HST on step hills.
   / ls tractor hst vs Fully Synchronized trans #5
Another value of an HST vs SS is if you do work where you have to approach the edge of a canyon - I had a mountainside road, a mile long, that I has to maintain and ditch. We frequently had rock/dirt slides during the winter that had to be cleared. Much of the road had a steep cliff on one side and a deep canyon on the other. The fallen debris was always dumped over the edge and that edge had to be approached with great care. I had a B-21 TLB/HST and would never have enjoyed having to clutch and brake as my front tires came within an inch of the canyon-side edge of the roadway to make the dump. The HST made it a piece of cake.
I have the shuttle xr4155 I致e used it quite a bit for loader work and it isn稚 that bad at all. I also do a lot of bush hogging in the summer sometimes on pretty hilly terrain which is why i went with the shuttle. No way i would want HST on step hills.
How many hours on your tractor ? I stopped at the dealer today . I don't know if I like LS a lot of plastic( rear fenders )I saw rust on the loader mount welds bleeding through the paint
   / ls tractor hst vs Fully Synchronized trans #7
117hrs I’ve owned it little less then a year. I’ve had some little silly problems. Clutch sensor plate rubbing the wire harness (dealer put a whole new harness on it) and a seal leaking where the front drive shaft comes out but other then that it’s a been a good tractor. I’ve yet to find anything i can get a bucket full of that it won’t lift or weeds/grass tall enough to bog it down pulling my 6ft bush hog. When i say tall I’m talking 6’ plus fields.
   / ls tractor hst vs Fully Synchronized trans #8
Gear drive puts more power to the ground and pto, it also uses less fuel... AND puts out waaaay less heat and noise.
SR
   / ls tractor hst vs Fully Synchronized trans #9
Doesn't JD & Kubota both use plastic fenders as well now? We demo'd both (and others) before settling on the LS. It's been a little while but would have sworn that they both used plastic fenders and hoods on the new ones we played with.
I think the kubota is still metal on most
UNUSED 2025 INDUSTRIAS AMERICA 7014 DUMP TRL (A51243)
UNUSED 2025...
2018 FORD F-150 (A52472)
2018 FORD F-150...
2020 EZ-GO Elite RXV Golf Cart (A50324)
2020 EZ-GO Elite...
1995 OTTAWA SPOT TRUCK (A50459)
1995 OTTAWA SPOT...
2014 CATERPILLAR CB54 XW SMOOTH DBL DRUM ROLLER (A51242)
2014 CATERPILLAR...
Wolverine Quick Attach Power Rake (A50514)
Wolverine Quick...
