LS XR4145 vs Kioti DK4710SE
   / LS XR4145 vs Kioti DK4710SE #1
East TX
TYM 574HC
Looking at both of these tractors with HST and cabs. Specs are about the same, 45 hp/4000lb/2500lb loader lift. LS is a hair cheaper. Ive seen some complaints about bucket speed with the LS. Dealers are both close by. So far, havent seen anything on them I dont like as far as driving around dealer lot. The Kioti seems to lose more HP at PTO vs engine according to specs, but i guess that could just be the way spec sheet is written. Any reason one would be better/worse from yall experience? It will mostly be used for light mowing, small deer food plots, cleaning brush with grapple. Twice a year Ill help my dad with haying. Which leads to the next questions. Both big enough to pull an 8 wheel rake id guess? Ive only ever pulled it with 50+hp tractor. Second, what is the biggest disc harrow I should look at?
   / LS XR4145 vs Kioti DK4710SE #2
I thoroughly researched a DK4710SE (open-station) a couple weeks ago and I loved pretty much everything about it. I think it's a great value for the money. It's horsepower numbers (45/33) are a bit lower than the model name would suggest so I will leave it to the more experienced users on this board to comment on haying and discing, but as for the tractor itself I think it's a solid choice. I'm not familiar with the LS so I can't provide much comment there. If you do choose to go with the Kioti, I'd talk to the dealer about adding a few options though. Namely the extendable links, linked pedal, and cruise control. Also fluid-filled rear tires would be a good option for the uses that you named.
UNUSED FUTURE FT1000T VIBRATORY ROAD ROLLER (A57192)
UNUSED FUTURE...
2009 Toyota Highlander SUV (A55853)
2009 Toyota...
UNUSED IRANCH 8" MINI EXCAVATOR BUCKET (A57193)
UNUSED IRANCH 8"...
(APPROX.52) UNUSED 2X4X12 LUMBER (A57192)
(APPROX.52) UNUSED...
(3) USED 3500 LB TRAILER AXLES (A57192)
(3) USED 3500 LB...
2019 Dodge Charger Sedan (A55853)
2019 Dodge Charger...
