LT 2042 Transmission Fluid Change
   / LT 2042 Transmission Fluid Change #1
ssallday
Brodheadsville, PA
05 CC 2042
I plan to change the transmission fluid on my LT2042 soon. It has the hydrostatic transmission and it calls for 6qts of cc’s drive system fluid(part#:737-3121). Is there a special procedure for changing the trans fluid? Are there any alternatives for this fluid? I would like to get a less expensive fluid but I will buy the the oem fluid if nothing else can match the quality.
   / LT 2042 Transmission Fluid Change #2
I and many other people use 10W40 motor oil. The Drive System Plus is synthetic so I use Mobil 1. You can buy 5 quarts at Walmart for $22 or so.
Bob B.
2020 Ford F350 DRW XL CC Crew Cab 4x4 Enclosed Service body (A45336)
2020 Ford F350 DRW...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A45676)
2017 FREIGHTLINER...
2006 HUMVEE UTILITY VEHICLE (A47001)
2006 HUMVEE...
KMC 3 P.T. 6 Row Peanut Inverter (A46443)
KMC 3 P.T. 6 Row...
AGT KRW23 (A46443)
AGT KRW23 (A46443)
WITTIG VACUUM PUMP (A47001)
WITTIG VACUUM PUMP...
