LT133 13 HP engine, gas leaking into the oil
   / LT133 13 HP engine, gas leaking into the oil #11
If your oil level is going up due to fuel getting into it, but the engine is running fine otherwise. Then you need a new fuel pump.
If fuel is dumping in to the intake manifold (from the carburetor) at a rate that would contaminate the oil, the engine would be running very rich, or more likely not at all. The spark plugs would be fouled, and the cylinders could even 'hydraulic' lock due to the excessive liquid fuel in them.
My $$ is on the fuel pump. It will leak fuel into the crankcase through the actuator lever opening. (Which is lubricated by engine oil, and runs off the camshaft.)
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
14' Bi-Parting Gate (A50120)
14' Bi-Parting...
2011 IC Corporation PB105 School Bus (A52377)
2011 IC...
2016 CATERPILLAR 259D SKID STEER (A52705)
2016 CATERPILLAR...
2012 Ford F-350 Crew Cab 4x4 Pickup Truck (A53422)
2012 Ford F-350...
