LT2180 PTO blet dimensions
   / LT2180 PTO blet dimensions #1
magicalj
Milan IN
[2004 LT2180] [1980 582] [1981 582] [1983 682] [1983 982]
Does anyone know the size of the PTO blet on a 2004 LT2180. Mine just self destucted and I would like to pick one up at tractor supply. Any help would be appreciated. Cub part number is 754-04041 if this helps anyone.
AJ
   / LT2180 PTO blet dimensions #2
Not sure of the size, however, TSC is a Cub dealer and should have the one you need.
Alan
   / LT2180 PTO blet dimensions #3
You will find a catalog at TSC that you can reference the tractor model number and find the belts for it. This will allow you to reference the belt size. (Cub obviously doesn't do this as they want you to buy the belts from them) They sell Kevlar belts at TSC that are better than the OEM belts, so it's worth the while to stop at TSC and do this.
-Fordlords-
Well I looked at my local TSC but they didn't have the cub cadet brand belt that fits my tractor. I also looked through the books but didn't find any references to that belt. I even looked at PIX's website but all I could find was the deck belt. I guess I'm goning to have to hit the dealer for a new one. I was hoping to get a kevlar belt for around the same price but I guess I can't always get what I want.
Thanks for the help,
AJ
   / LT2180 PTO blet dimensions #5
Did you try having the old belt sized at an auto parts store? They should be able to give you the info you need.
Alan
   / LT2180 PTO blet dimensions #6
Is it the 42" deck on the 2180? Those decks have been around for a long time, aftermarket belts should be easy to source. The 44" hasent been around too long so it may not be so easy. I know I need to p/up a spare for my 44".
Joel
As far as I can tell, this belt is only used on the LT2138, LT2180, LT2042, GT2186-44 and the GT2542. It doesn't seem like there are a lot of models running this belt. But with all the searching, I just can't find the dimensions of it. Guess I have to take a trip to the dealer.
AJ
   / LT2180 PTO blet dimensions #8
This belt is 111.2 inches long. Don't know what the width is though. Hope this helps.
   / LT2180 PTO blet dimensions #9
It's going to be 5/8" or 1/2", that should be easy to tell with the old belt.
-Fordlords-
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A58216)
2011 MULTIQUIP...
2088 Chevrolet C7500 Altec TA40 41ft. Bucket Truck (A59230)
2088 Chevrolet...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
iDrive TDS-2010H...
TEST YOUR BID BUTTON! (A60429)
TEST YOUR BID...
