LTX1046KW grease points????
   / LTX1046KW grease points???? #1
whitearrow
philadelphia,ms
john deere 5203
Good morn fellas. I've got said cub and I've found 4 grease zerks. 2 on each end of the axle and 1 per front wheel. I got under it and looked for a zerk on the spindle but did not see any. Is there any that I'm missing?
Thanks,
Big Ed
Thanks and I've seen that but I don't know whether they put diff spindles on the kw with the kawi engines but mine doesn't have a zerk there.
   / LTX1046KW grease points???? #4
Some of the spindles on Cubs have sealed bearings and do not have zerks. Some Cub spindles have sealed bearings and DO have zerks that are useless. Some Cubs have spindles that have zerks that are way up inside the center of the spindle where it is impossible to get to without removing the deck and flipping it upside down. I think it's all a matter of what Chinese spindle supplier had parts on the shelf at MTD when they built your mower.
Mine has the "impossible to get to" zerks. They get greased maybe every other season or whenever the deck has to come off for something. If I never have to remove the deck, I'll just run the spindles to failure.
2019 BOBCAT E45 EXCAVATOR (A59823)
2019 BOBCAT E45...
2018 Toro Sand Pro 5040 Bunker Rake (A59228)
2018 Toro Sand Pro...
1747 (A60430)
1747 (A60430)
Kubota RTV X900 (A53317)
Kubota RTV X900...
2020 Case 5550 Trident (A61307)
2020 Case 5550...
Dump Truck Body with Tarp System (A55851)
Dump Truck Body...
