lubricant
   / lubricant #11
if the counter guy didnt point you at the 85-405 , when you asked for a utf type oil.. I'd complain to the manager and the regional manager if a corporate store... they charged you DOUBLE what you needed to pay! I'd be piping mad!
   / lubricant #12
It's multi-grade oil, but NOT motor oil. Yes, all those things you mentioned use Multi-G 134 or equivalent. It makes buying fluids easy. All you need is a good diesel motor oil, the hydraulic/transmission fluid, and grease.
Is this what I shoud also use in the Gear case on the Front wheel axle on a FWD 1310?
   / lubricant #13
i'd be surprised if 134d oil was not specified for the front axle. it was in my 1920
2012 CAT 316EL (A55272)
2012 CAT 316EL...
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
KMC 70Z7 WHEEL LOADER (A52709)
KMC 70Z7 WHEEL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
1952 Army Jeep M38 (A57453)
1952 Army Jeep M38...
Unused 20x20 Carport With 10' Half Enclosed Side Walls (A55272)
Unused 20x20...
