lubricating oils
   / lubricating oils #1
shrekbelly
guys,
i need to start a regular oiling and greasing schedule on my bx. have also got confusing advice on what to use.
what is the concensus on good oils, for my new oiling can/pump. as always, any input is greatly appreciated . . . . to old and broken down, ought to know better . . . hookopotomous regards, shrekbelly
   / lubricating oils #4
gwdixon, steered you right, follow your manual for greasing all points and change your engine oil at least once a year even if your hours are low. I did this on my BX23 TLB and never had a issue. You may want to use synthetics oils if you live in colder areas for the winter, It makes starts a bit easier on engine.
DevilDog
   / lubricating oils #5
For engine oil I have used Rotella, Kubota and New Holland, SUDT for the transmission; lithium base in grease gun. I use mine year round, so I go by hours, but if you don't put enough hours, I would change engine oil yearly anyway unless stored in a heated place. The BX is really simple to service.
   / lubricating oils
sorry i'm such a dreadful communicator, i was/am curious if there's a preferred brand on 3 in 1 lubricant (i have my greases & engine oils lined up).
thanks, shrekbelly
   / lubricating oils #8
I use Breakfree CLP.
   / lubricating oils #9
@TripleR: I used to use a gun oil called CLP that came in jugs and I don't recall a brand name on it....had teflon particles in it. Is that the stuff you use?
   / lubricating oils #10
Yep that is the stuff. They make several different formulations including those for high temperature applications in fully automatic weapons. The SEALS used it at one time. I use it on guns, presses and just about everything.
KUBOTA B7510 TRACTOR (A51247)
KUBOTA B7510...
PALLET OF ARMSTRONG CEILING INSULATION (A51248)
PALLET OF...
12' CONTAINER (A51248)
2010 Ford Crown Victoria Sedan (A51694)
2010 Ford Crown...
Year: 2008 Make: Cadillac Model: Escalade ESV Vehicle Type: Multipurpose Vehicle (MPV) Mileage: (A51694)
Year: 2008 Make...
2010 Chevrolet Malibu LTZ Sedan (A51694)
2010 Chevrolet...
