Lucky to be ALIVE!!!
   / Lucky to be ALIVE!!! #231
I agree you can make s bad choice at any age. I thought I had kind of grown out of some of those decisions though. Obviously not. I should have disconnected battery or atleast double checked the shifter out of gear. Good news at the Dr. today. Everything doing good, x-Rays show everything back where it should be. It's been 3 weeks since accident and told at 6 weeks normal activity ok within reason. I'm not sure when I'll be back to 100%, but have high hopes it will be soon. Time will tell & I'm getting a little better each day. I'm very greatful for everyone's prayers, well wishes, understanding and support. It has helped much.
I'm glad to hear the optimistic news,Garycw. Hang in there.
Terry
   / Lucky to be ALIVE!!! #232
Gary,
Glad to hear things are going well for you.
The other bantering in the thread is nearly repulsive, but you've handled it like a gentleman. I keep telling myself that everyone means well at heart, and is just trying to sort out the details of what happened.
I've been an electrician for most of my teen and adult life, and different terms that were intended to mean the same thing often causes confusions and communication issues. Hope we are past that now.
Take care and be well...
   / Lucky to be ALIVE!!! #233
That is great news Gary.
Hind sight is always 20/20. One time in my late 20's I came close to killing myself with something that, in hindsight, I knew I should have done better. It wasn't tractor related in any way, but I distinctly remember getting up off the ground onto my my knees and thanking God that I was still alive. There are many of us out here who truly can testify to the fact that it doesn't matter your age or what you know, sometimes people just make mistakes. There is a human phenomenon where sometimes the mind can get so focused on the task at hand that we fail to recognize the dangers, the same dangers we would call attention to if we were just standing back and watching someone else do the same job. The important thing is how we adjust and respond afterwards. And from your posts it sounds to me like you are doing great. I would agree with dieselcrawler that you've handled yourself like a gentlemen. It takes a big man to stand up and admit his mistake to help others avoid the same fate. All of this other wrench forensics stuff is distracting from your simple message of disconnecting the battery and making sure that the tractor is out of gear.
Very well said Milkman. If I was watching someone attempting to do what I did, I would have most likely stopped them immediately. Thank You.
   / Lucky to be ALIVE!!! #235
I skipped some post because of the be in some posts.
Gary glad your progressing in your recovery.
Ill try and put the stupid argument about shorting to bed.
Imagine you put a 50 amp fuse in line at the battery.
Short across the solenoid terminals, you pick up the load from the starter.
Now short the solenoid to ground. The fuse will blow.
   / Lucky to be ALIVE!!! #236
Well, you might have the right idea, but your analogy is flawed :c). Problem is, most starter motors will draw a fair amount of current, over 150 amps is not uncommon for a starter turning a high compression (think diesel) or big displacement engine. Your wee little 50 amp fuse would blow if it were in the circuit when you "connect" the two heavy solenoid terminals with that wrench. But you are in luck, 'cause the negative terminal of the battery is connected to chassis ground, and the positive terminal has a heavy wire going from it directly to one of the big connectors on the solenoid. The other big solenoid terminal goes to the starter motor, of course, and the other starter motor terminal (internal and not exposed), is connected to chassis ground. For obvious high current reasons, no fuses are in the starter circuit in most every vehicle I'm aware of.
It's just like a loop (circuit) with the "open" in the circuit being between those two terminals on the solenoid (at least until there is voltage applied to the solenoid coil - usually from the starter switch). Connect them contacts one way or another and current (wee little electrons) can then flow from the negative terminal of the battery, through the chassis to the negative or ground side of the starter motor, through its motor windings to its positive terminal, and then through the solenoid contacts back to the positive terminal of the battery. (Note, this describes the more widely accepted "electron flow theory" as opposed to the out dated "conventional current flow theory", that has electricity flowing from battery positive to negative - confusing, I know).
In any case, connect battery positive or a wire connected to it, directly to chassis ground and you will get arcs and sparks, blown fuses or welding - - don't do it. Connect those two solenoid terminals (also sometimes called a contactor or relay) together and the starter motor turns - - if she's in gear things get dicey.
No electrons were harmed writing this post. This post contains no viruses, bugs, or misinformation, grammatical errors, maybe, but my hearts in the right place. May the electromotive force (EMF to you neophytes) be with you,
PS, If you don't really know how something works, it's usually safe to conclude it works by PFM (pure, xxxxing, magic).
bumper
My credentials? 8 years as a Navy electronics technician (63 to 70), founded and still own an electronics related company (kids run it now), licensed electrician, played with this stuff all my life. Disclaimer, none of this means I'm right . . . but I sure think I am.
   / Lucky to be ALIVE!!! #237
Here we go again, only the names have changed.
   / Lucky to be ALIVE!!! #238
Life is short. Then you're in the ground.
   / Lucky to be ALIVE!!! #239
What? I've been here since the beginning. Just chose to ignore much of the misinformation and incorrect posts (oh, and there's been a goodly number of spot on posts too). But I know there's little hope of teaching electronics or even basic electricity in a few posts here. Last couple of years in the Navy I taught crypto equipment at Mare Island, so I've seen and recognize when the class is completely flummoxed by a concept :x) Just, couldn't help myself and had to give it one more shot.
"Clear prop!"
bumper
Giyi Hydro Pallet Forks (A53316)
Giyi Hydro Pallet...
Heavy Duty Aluminum Service Truck Bed Rack (A55787)
Heavy Duty...
2005 Ford F-650 2,000 Gallon Water Truck (A55788)
2005 Ford F-650...
2017 Freightliner MT55 Box Truck (A55788)
2017 Freightliner...
2007 GMC W4500 Landscape Dump Truck (A55788)
2007 GMC W4500...
Rocford  Power Unit (A53314)
Rocford Power...
