Lug Nuts are STUCK!
   / Lug Nuts are STUCK! #11
My 4-way cost me $600 about thirteen years ago...
About $15 for the wrench, and about $585 for new front teeth when the little L-shape lug wrench I had been pushing down on with my foot, sprung up and turned the front teeth to powder...I was lucky...the teeth could be replaced. Could have been an eye... /forums/images/graemlins/frown.gif
Still not sure why my foot slipped off that little wrench...
   / Lug Nuts are STUCK! #12
</font><font color="blue" class="small">( Still not sure why my foot slipped off that little wrench )</font>
I'll bet if your foot hadn't slipped off the wrench, the wrench would have slipped off the lug nut. Either way is not good. /forums/images/graemlins/frown.gif
   / Lug Nuts are STUCK! #13
I'm with you bird. I also carry the 4-way. /forums/images/graemlins/wink.gif
   / Lug Nuts are STUCK! #14
For my car I have AAA, for everything else, I have my Snap On 1/2" drive impact. 40 years old and still going strong... It's Priceless. /forums/images/graemlins/grin.gif
   / Lug Nuts are STUCK! #15
Had to use my 4 way today on the mail route luckly the lug nuts weren't to tight so I was able to change the tire myself. /forums/images/graemlins/laugh.gif Not 1 person drove by while I was changing it, the minute I started to clean up my hands after it was all done 2 cars drove by. /forums/images/graemlins/tongue.gif
Lisa
   / Lug Nuts are STUCK! #16
I forget where I read this but, it sounded realistic to me:
Don't put never-seize on the lug bolts or nuts. The never-seize is TOO good at it's job and can cause lug nuts to loosen over time with cooling and heating. This is likely not too much of a problem on tractors but is more applicable to automobiles. It was recommended to use a light oil on the threads, and as mentioned, only on the bolt, not in the nut. And don't use too much, more is not always better.
   / Lug Nuts are STUCK! #17
I have been using in on my car lug nuts for over 25 years so far and with the exception of the loose nut behind the steering wheel, I have never had a problem. /forums/images/graemlins/grin.gif
   / Lug Nuts are STUCK! #18
I must disagree or be an exception because I have been using it on all lug nuts since 1991 (or around) and never had a problem. If any, it might cause over torqueing since lubes on threads increase torque anywhere from 5 to 18%
   / Lug Nuts are STUCK! #19
I put never seize on the lug threads too. For that matter on most everything I can. Have never had anything back out or loosen up. Dry threads and a dry taper on the lugs can give you inaccurate torque due to the friction of threads or mating taper durface.
   / Lug Nuts are STUCK! #20
I usually give a quick squirt of WD-40 ( Water Displacement on the 40th try ) to the studs when I have a wheel off. This has worked good for me. /forums/images/graemlins/wink.gif
2016 JOHN DEERE 35G EXCAVATOR (A60429)
2016 JOHN DEERE...
2005 MACK TRI AXLE DUMP TRUCK (A52707)
2005 MACK TRI AXLE...
Redirective Crash Cushion Guardrail (A59230)
Redirective Crash...
TAYLOR WAY 962 48" HYD TILLER (A57192)
TAYLOR WAY 962 48"...
2020 INTERNATIONAL REEFER TRUCK (A58214)
2020 INTERNATIONAL...
JOHN DEERE 310K (A58214)
JOHN DEERE 310K...
