LX176 Spark Plug Blow Out
   / LX176 Spark Plug Blow Out #1
JD-LX176
I had a spark plug blow out on a John Deere LX176. The dealer had to remove the head and install a spark plug insert. The bill reads 3.7 hours to complete this repair which seems like a long time to me.
Can anyone tell me if this seems excessive or how long something like this should really take? I'm not familar with small engine repairs so any guidance anyone could provide would be very much appreicated.
I would like to be a little more knowledgeable about this before giving the dealer a call.
Thanks!
   / LX176 Spark Plug Blow Out #2
I would bet that the dealer is using a flat-rate service manual. That is, it tells him to do the repair there is 3.7 chargeable hours involved, regardless of how much time he actually spends on the repair.
And personally I do believe that removing a head and installing an insert could easily chew up that much time.
   / LX176 Spark Plug Blow Out #3
Thanks!
At the going labor rate.. i wonder if a new head might have been cheaper?
Soundguy
   / LX176 Spark Plug Blow Out #4
He could have probably done the job without removing the head. I've done that on cars and trucks before. All you need to do is spin the motor over to blow out the small chips from retapping the hole for the insert.
   / LX176 Spark Plug Blow Out #5
I'm no engine expert but I wouldn't think that would be too good on the cylinder and rings.
   / LX176 Spark Plug Blow Out #6
ditto......
   / LX176 Spark Plug Blow Out #7
Just curious what is your dealers labor rate?
Ken
   / LX176 Spark Plug Blow Out #8
Sound guy,
I'll bet the labor would have been nearly the same, minus tapping.
patrick
Thank you all who have provided feedback - I'm still interested in more.
To answer the labor rate quoted posted by KENSFM. It is $60 an hour.
   / LX176 Spark Plug Blow Out #10
Paddy said:
Sound guy,
patrick
Labor? heck.. i can put a couple head bolts in a lawnmower engine...
Soundguy
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2011 NORAM POWER SYSTEMS 100KW GENERATOR (A58214)
2011 NORAM POWER...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
THREE POINT ATTACHMENT (A58214)
THREE POINT...
Cummins 6-Cylinder Diesel Engine with Transmission (A59230)
Cummins 6-Cylinder...
Tank Only (A59076)
Tank Only (A59076)
