M with knock
   / M with knock
Well, the center main is BAD. At least it didn't spin.
So far I can only find the main bearings for sale as a kit, can't find the center thrust bearing individually.
So it looks like we replace all three mains.
Thanks for all the advice.
   / M with knock #12
i figured you'd find a main bad with a knock that din't go away with spark plug wire disconnect.. rods will quiet up pretty good when you pull the plug.. etc..
   / M with knock #13
This is a long shot but the earlier M's had cast iron pistons. The iron pistons had looser tolerances so they made a knocking type noise. One of my cousins had one, it sounded like a 560 Diesel while idling!! Not a expert, just throwing out what little I remember from way back when. :)
   / M with knock #14
can they knurl them pistons or not?
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A53843)
2011 MAGNUM...
Doosan P250 Trailer Mounted Air Compressor (A53117)
Doosan P250...
2017 Mack GU713 Granite Tri-Axle Dump Truck (A51692)
2017 Mack GU713...
1984 Utility 44 ft. Reefer Trailer (A53117)
1984 Utility 44...
2017 Ford Explorer SUV (A51694)
2017 Ford Explorer...
10" Shaver Post Driver (A52384)
10" Shaver Post...
