M4900 Engine Torque?
   / M4900 Engine Torque? #1
LeadPoison
Platinum Member
Kubota M4900
Anyone know the engine foot pounds on the 54 HP version of the M4900?
   / M4900 Engine Torque? #2
LeadPosion
54 HP version ?
My M4900 manual says 50.5 net hp and max torque 126.1@ 1400 to1600 rpm.
I suppose the gross hp maybe 54 hp.
While those are the numbers in my day to day use I would say it has plenty!
Dave
54 HP is the gross HP.
From what I understand Kubota has bumped the HP a few over the lifestyle of the model.
Thanks for the info.
Where were you able to find it?
   / M4900 Engine Torque? #4
That is good to know as well. I guess there is an advantage to buying near the end of a production run.
I found the info in the operators manual, in the specifications section.
Dave
Thanks for the info. I totally overlooked it in the manual.
   / M4900 Engine Torque? #6
These tractors (M4700, M4900, M5400, M5700) all use the same basic engine - the F2803 - 5-cylinders, 167 cu in smoothie that dates back to the mid '80's. In the various models (Also used in the L4150, L4850, L5450) the HP rating has been between 50 and 60 gross hp. The "rated" hp is at different rpm's (2600, 2800 or "estimated") so nailing down a precise number for comparison purposes is not documented. This engine makes gobs of torque (120-130 ft-lb at 1300-1500 rpm). I've always thought the diesel pump/injector setup made the small differences in models. My L5450 has the 59.5 gross hp version. Have also noticed stationary generators and other industrial equipment list models with Kubota F2803 engines.
   / M4900 Engine Torque? #7
rbargeron
Thanks for the history, very interesting. I actually looked at a used L5450 before buying my M4900. Those tractors have very impressive spec's, the one I looked at was just a little to "used" for me.
I certainly agree that the 5 cyl. is very smooth.
Dave
2015 Ford Explorer AWD SUV (A44572)
2015 Ford Explorer...
EZ Go Golf Cart 48V (A44391)
EZ Go Golf Cart...
2005 Sterling L7500 Series Fuel/Lube Truck, VIN # 2FZHATDC95AV42993 (A44391)
2005 Sterling...
2017 Rotair Sand Blaster and Trailer (A44391)
2017 Rotair Sand...
2015 Ford F-550 4x4 Bucket Truck (A44571)
2015 Ford F-550...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A43003)
2016 FREIGHTLINER...
