m7040 busted hydraulic hose
   / m7040 busted hydraulic hose #1
m7040
Elite Member
Frederick maryland
Kubota M7040, MF 203 industrial, ZD331, RTV 1100 , Kubota Minix excavator, Unimog 404
yesterday wile digging ot an old gas tank on the farm I busted a hydraulic hose for the FEL curl function. Lots of oil spray before I could shut it off.
Is that one of the hazards that needs to be cautioned against?
Think that slamming into the dirt with the bucket tilted caused too much pressure in the line and ruptured the hose.
   / m7040 busted hydraulic hose #2
Quite possibly. When you replace the hose make sure the new one is at least a 2-wire hose rated for 4000 psi or greater.
   / m7040 busted hydraulic hose #3
It won't be your last, wear saftey glasses unless you have a cab.
I got sprayed three times with my previous tractor and all three times I had to wipe hydraulic oil off my saftey glasses.
   / m7040 busted hydraulic hose #4
I understand that pushing with the bucket in the down position puts tremendous pressure on the hydraulic system. I'm wondering (since I only have a cursory knowledge of hydraulics) why the pressure release valve didn't prevent this?
   / m7040 busted hydraulic hose #5
Because there is no pressure relief on the work ports. When the spool is in the neutral position you have a mini-circuit between the spool's two work ports and the cylinder. Since fluid is blocked from exhausting when in neutral, something has to give. It's usually the hose but sometimes the valve actually cracks or splits open. A rather dangerous situation.
On most heavy equipment there is a relief on each work port, or at least those that have the potential for problems like the bucket curl. My dozer has reliefs on the bucket curl work port, the clam open and the clam close. But then again the breakout force on most dozers is pretty high, mine is 18,500 lbs.
Thanks for the advice. I have a cab so it was safe but lots of oil all over. Dealer replaced the hose this morning on warranty so I am ready to install it. Think one needs to be careful with the curl function and keep it fairly level when applying force with 4 wheel drive. Seems it will break the hose if not. On my two wheel drive MF 203 loader it has not been a problem because I think the traction is more limited.
   / m7040 busted hydraulic hose #7
Using four wheel drive to push the bucket into the ground below a level angle will certainly result in blown hydraulic lines or a messed up FEL linkage. Often the rigid metal hydraulic pipes burst before the flexible rubber hoses go too. If you want to try to prevent or lessen the chance of this happening, use only two wheel drive.
I installed a hydraulic pressure gauge (0-5,000 psi) onto my L-3130 LA723 FEL control linkage adjacent to the dashboard so that I can see the hydraulic pressure all the time with a quick glance.
   / m7040 busted hydraulic hose #8
You must have a real good relationship with your dealer since hoses are not covered under warranty:)
I did not know that hoses are not covered.
   / m7040 busted hydraulic hose #10
Mine was. Broke one on the FEL and dealer fixed it on-site.
Russell in Texas
2021 BOBCAT T450 SKID STEER (A51246)
2021 BOBCAT T450...
2011 TRAIL KING LOWBOY TRAILER (A50459)
2011 TRAIL KING...
2022 JOHN DEERE 6120M LOT NUMBER 191 (A53084)
2022 JOHN DEERE...
2011 INGERSOLL RAND  G70 GENERATOR (A52472)
2011 INGERSOLL...
2019 Fecon BH74SS Hydraulic Mulcher High Flow Skid Steer Attachment (A51691)
2019 Fecon BH74SS...
1996 International 4700 Box Truck, VIN # 1HTSCABP2TH265415 (A51572)
1996 International...
