M9540 transmission options and road speed
   / M9540 transmission options and road speed #1
grader guy
central, massachusetts
2012 John Deere 5093e
Hi, I can't find any information in regards to travel speed. How fast will the tractor with the 8 speed go? How fast will one go with the 12 speed? Thanks in advance!! Matt
   / M9540 transmission options and road speed #2
According to the sticker on my fender, my 9540 with the 12sp. does about 18mph. with 18.4 X 30 rubber.
   / M9540 transmission options and road speed #3
Same for our M8540, I don't know about the 8 speed as I didn't even consider nor would I recommend it on these tractors.
   / M9540 transmission options and road speed #4
It has been a while since I researched it, however I think the top (and bottom) speeds were the same between the 4 and 6 gear transmissions (8 and 12 speed). With the 2 extra gears (4 speeds) you had more granularity in between.
The 12 speed hydro shuttle is definitely worth it. This is especially true when you consider the other options/features that come with it.
   / M9540 transmission options and road speed #5
i definitely 2nd that
   / M9540 transmission options and road speed #6
I'm gonna take a wild guess that you're thinking getting one for plowing snow, and wondering about traveling time between jobs. ???
Bingo!! yes trying to see what tractors would put me over 20 mph. My m7040 only does about 15-16 mph. I think I have read that the M60 series go faster, but not totally sure. Thanks for all the responses!! Matt
   / M9540 transmission options and road speed #8
Fast tractors are very expensive!!
I'd love a JCB Fastrac.
   / M9540 transmission options and road speed #9
My M9540 12 speed shows 23+ mph on the road unless I hit a hill. The 8 speeds are painfully slower.
The M60 12 speed tractors are electronically governed in H6 to roughly the same. Defeat that and you might squeeze 3-4 more mph out of it.
   / M9540 transmission options and road speed #10
I have a 9540 in the 24 speed option. The speedo shows 26 mph wot. I believe it to be accurate as I travel fairly quick between my farms.
2025 Mini Excavator Bucket Attachments (A45336)
2025 Mini...
2011 PETERBILT 365 WIRELINE TRUCK (A45333)
2011 PETERBILT 365...
PT PTO Driven Canal Pump (A47307)
PT PTO Driven...
DigMaster DM100 Mini Excavator (A43476)
DigMaster DM100...
MLE 4188CR Clean Room Scissor Lift (A44571)
MLE 4188CR Clean...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A45336)
2021 Ver-Mac...
