M9540 transmission options and road speed
/ M9540 transmission options and road speed #1
grader guy
Member
central, massachusetts
2012 John Deere 5093e
Hi, I can't find any information in regards to travel speed. How fast will the tractor with the 8 speed go? How fast will one go with the 12 speed? Thanks in advance!! Matt
/ M9540 transmission options and road speed #2
According to the sticker on my fender, my 9540 with the 12sp. does about 18mph. with 18.4 X 30 rubber.
/ M9540 transmission options and road speed #3
Same for our M8540, I don't know about the 8 speed as I didn't even consider nor would I recommend it on these tractors.
/ M9540 transmission options and road speed #4
It has been a while since I researched it, however I think the top (and bottom) speeds were the same between the 4 and 6 gear transmissions (8 and 12 speed). With the 2 extra gears (4 speeds) you had more granularity in between.
The 12 speed hydro shuttle is definitely worth it. This is especially true when you consider the other options/features that come with it.
/ M9540 transmission options and road speed #5
i definitely 2nd that
/ M9540 transmission options and road speed #6
I'm gonna take a wild guess that you're thinking getting one for plowing snow, and wondering about traveling time between jobs. ???
Bingo!! yes trying to see what tractors would put me over 20 mph. My m7040 only does about 15-16 mph. I think I have read that the M60 series go faster, but not totally sure. Thanks for all the responses!! Matt
/ M9540 transmission options and road speed #8
Fast tractors are very expensive!!
I'd love a JCB Fastrac.
/ M9540 transmission options and road speed #9
My M9540 12 speed shows 23+ mph on the road unless I hit a hill. The 8 speeds are painfully slower.
The M60 12 speed tractors are electronically governed in H6 to roughly the same. Defeat that and you might squeeze 3-4 more mph out of it.
/ M9540 transmission options and road speed #10
I have a 9540 in the 24 speed option. The speedo shows 26 mph wot. I believe it to be accurate as I travel fairly quick between my farms.
/ M9540 transmission options and road speed #11
24 speed. :drool:
/ M9540 transmission options and road speed #13
Something to keep in mind with this discussion is tire type and size. My M8540HD12 tops out at 15 or 18 MPH, however I have R4s which are significantly shorter than the R1 offerings for that model. Everyone should include their tire type/height along with their trans configuration for an apples-to-apples comparison.
/ M9540 transmission options and road speed #14
The m60 series are faster. I have a M7060 with the 12 speed and r1 tires and it will do 25mph
/ M9540 transmission options and road speed #15
/ M9540 transmission options and road speed #16
I think that they "set up" euro tractors with higher road speeds. I wonder if Canada is equipped the same? On our roads here, I'd need a 5 point racing harness to stay anywhere near the tractor at 25 mph:laughing:
/ M9540 transmission options and road speed #17
Have you seen mention of anyone doing this? I have been looking with little luck. Overriding The 1960RPM limit (24.3mph or 38.9kph) and letting it turn 2400 would on paper give you 5.5Mph more (29.8mph or 47.95kph)
/ M9540 transmission options and road speed #18
I have not.
My dealer and I fantasized about it over lunch one day but as far as I know he never looked in to actually doing it.
I'll bring it up tomorrow and see what he says.
/ M9540 transmission options and road speed #19
Let me provide a bit of info here. Lets take two tractors - one tops out at 18mph, the second is a "racer" and tops out at 24mph.
Now lets do a bit of math and see what happens.
Over a ten mile distance- the "slow" tractor will take - - 33 minutes, the "racer" will get to the end in 25 minutes
The same tractors over a five mile run - slow boy gets there in 16.5 minutes, racer is there in 12.5 minutes
Again over a 2.5 mile run the "turtle" will arrive in 8.25 minutes, 'ol fastie is there in 6.25 minutes
IMHO - I would be a little more concerned with the abilities of the unit rather than its speed.
/ M9540 transmission options and road speed #20
What ever, it feels good when I drop out and pass my neighbor on his (other color) tractor. No, I'm not joking.
2014 Freightliner Cascadia 125 S/A Day Cab Truck Tractor (A59230)
2014 Freightliner...
CAT D8 (A58214)
CAT D8 (A58214)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Kubota LA525 Front Loader Tractor Arm Attachment (A59228)
Kubota LA525 Front...
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
2024 UTILITY VS2DX 53FT DRY VAN TRAILER (A59905)
2024 UTILITY VS2DX...
