SDT
Veteran Member
I'm finally getting around to replacing the Woods BB840X 7' mounted cutter that I have been using with my M9960 ROPS that I bought about 2 years ago.
Ground is clean and most of the areas where I will use the BW are not steep but there are some areas where I can allow a BW to ride along a hillside extending beneath the tree canopy to avoid driving beneath tree limbs with my L6060 ROPS and 6' cutter, as I regularly do now.
I'm sold on Woods mowers and was originally considering a Woods BW 12, 12' cutter because it is a combination of 3, 5' decks and will cut more cleanly than a larger BW (I use my cutters more as HD finish mowers than rough cut mowers), is less expensive than a larger BW, I really do not need anything larger, and the transport width makes it much easier to get into and out of my 12" door.
That said, my dealer has a Woods BW180X, 15' BW priced only $2,200 more than the BW12. The BW180X is heavier, has larger tires, larger gearboxes and cuts 3' wider. This appears to be a better deal than the BW12, but because of the wider cut and combination of 3, 6' decks, it will be more prone to scalping than the BW12. It will also be more of a challenge to get into and out of my 12' door, but manageable by lowering the height cylinder to pull the wing wheels further in.
I paid extra for optional EPTO for my 9960 ROPS, and use it regularly with my BB840X 7' cutter. Obviously, I will not be able to use it with either BW because, when engaged, 540 PTO RPM is only about 1,650 engine RPM, and the engine makes insufficient torque at such low RPM to handle anything beyond my current 7' cutter (Grrrrrr).
Also considering buying another 80 acre adjoining parcel (lots of details to work out before doing so) with a 50 acre field that I would need to mow occasionally. Really never considered anything larger than the nice, compact BW12 before considering the adjoining parcel.
Haven't bought a larger cutter yet, and looking for relevant advice from those of you with similar situations.
Decisions, decisions....
SDT
SDT
