MacKissic shredder not starting after jam
   / MacKissic shredder not starting after jam #11
Have to go on the pull rope side. The shroud will need to be removed to aid in the removal of the flywheel nut and flywheel.
Remove nut and washer,then f/w. Might have to use a pry bar to pry out on f/w.
Put pry bar just barely under f/w, not wanting to pinch wires or bend anything.
Reinstall nut flush to the crank shaft threads. no threads sticking up past the nut.
Putting pressure on pry bar and using a brass hammer "squarely" hit the end of crank shaft.
F/w should pop off, if not-turn f/w 180 degrees and try again. Keep turning,prying and hitting til it pops off. Pick up key or pieces and head to the small engine repairman.
Line up f/w slot and crank shaft slot. insert new key,washer,nut and tighten nut to specs.
Reinstall dry!!!
DO NOT USE OIL OR GREASE ON CRANKSHAFT-FLYWHEEL OR KEY!!!
Reinstall shroud and any other parts removed previously.
Remove plug and pull rope slowly to see if anything binds or rubs.
Install plug and fire it up!
T.J.
(8) 2 PLUG VALVES (A52472)
(8) 2 PLUG VALVES...
2014 FORD F250 XL SUPER DUTY CREW CAB TRUCK (A51406)
2014 FORD F250 XL...
2000 FORD F650 SINGLE AXLE DUMP TRUCK (A52472)
2000 FORD F650...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
2022 NEW HOLLAND 266BMM 66-INCH BELLY MOUNT FINISHING MOWER WITH SIDE DISCHARGE (A52748)
2022 NEW HOLLAND...
2007 Ford Focus Hatchback (A51694)
2007 Ford Focus...
