Mag-Torch any good?
   / Mag-Torch any good? #1
npalen
Elite Member
Beloit, KS
Kubota B9200 HSTD and Mahindra 3015
   / Mag-Torch any good? #2
let me start by saying no I havent tried it.
But how good it is just depends on your expectations. Dont go in thinking you are buying a "welder" or a real "cutting torch". What are you wanting to do with it??
   / Mag-Torch any good? #3
True MAPP has been extinct for 5 yrs and tho' it's replacements (MAPD, 'MAPP-Pro') aren't much hotter than propane 'in free air' adding oxygen better replicates the performance of the original. You don't want to weld steel with MAPP, MAPD, or MAPP-Pro as hydrogen absorption will make the welds brittle.
I worked at M__ Muffler 35 yrs ago. Propane with O2 cut clamps & shock mount bolts like butter and the acetylene cart was the dustiest and least used tool in the shop. (w/coat-hanger, but not much to weld there, actually) Plumbers still prefer MAPP with lead free solder for the extra hundred+ degrees and higher BTU. Most importantly, head/tip types are critical to getting the most from the pricier gas, as is using it with O2.
If you want to cut or braze with the above kit I doubt you'd be disappointed. Having the best tip on there it'd be my 1st chioice. Wouldn't cost much to prove me right or wrong about it for the task & it sure sounds easier to use than the carbon-arc torch I usually braze with. :eek: Give it a shot & tell us what YOU think. If it bombs we can always take up a collection to cover you investment. :rolleyes:
   / Mag-Torch any good? #4
It will cost you a fortune buying new cylinders for every 3 minutes of cutting time. What do plan to use it for?
   / Mag-Torch any good? #5
I had a similar one years ago. Those little 1 cubic foot oxygen cylinders made the thing basically worthless. Sure you can get a hotter and more concentrated flame than a basic propane or MAPP/air torch, but I wouldn't waste my money on another one of those!
   / Mag-Torch any good? #6
The oxygen bottles will bankrupt you if you try to do much of anything with it.
   / Mag-Torch any good? #8
You can't fill the acetylene from another cylinder. Unless you have to carry the torch up stairs or to some remote location you can't get to, get a 75 cu. ft. acetylene cylinder and an 80 or preferably a 122 cu. ft. oxygen. You'll have enough capacity for most jobs and standard regulators will fit this size cylinder. Even the little portable totes are only good for about 15 minutes of cutting at the most.
   / Mag-Torch any good? #9
Sure you can or at least I do. You need to do it very, very slowly though. You want to transfer the acetylene only, not any of the acetone.
How long they last, depends on what you are doing with them. A rosebud, cutting torch and welding tips all use the gases at different rates, not to mention the different orifices you might have for any of the processes.
   / Mag-Torch any good? #10
That's SCARY! I doubt your gas supplier is aware that you're filling acetylene from a larger cylinder. I work at a welding supply and all the acetylene cylinders are shipped to the main fill plant where they are filled in a controlled environment. Hopefully no one will follow your practice of transferring acetylene from one cylinder to another. I believe it's illegal. Oxygen and most high pressure gases can be transferred though.
SCAN TO RECEIVE TEXT UPDATES (A60429)
SCAN TO RECEIVE...
Woods 1800 Batwing Mower (A59814)
Woods 1800 Batwing...
204549 (A52707)
204549 (A52707)
2001 Workhorse Custom Chassis P42 Delivery Truck (A59230)
2001 Workhorse...
2015 Peterbilt Dump Truck (A55973)
2015 Peterbilt...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
