Magnetic Heater for tranny or engine block?
   / Magnetic Heater for tranny or engine block? #1
Doc_Bob
Elite Member
Wisconsin
2003 NH TN70A
   / Magnetic Heater for tranny or engine block? #2
Doc Bob:
The magnetic Heater needs ferrous metal to attach to. It will not attach to aluminum block engines. I discovered this reality with my old Ford 1100. I did find metal that I could attach the magnetic heater to and it appeared to work. Jay
jbrumberg said:
Doc Bob:
So it got warm? Or hot? I am curious, it looks like the magnetic heater can get hot. Is the actual device so hot that it is too hot to remove?
Bob
   / Magnetic Heater for tranny or engine block? #5
Doc Bob
They get hot alright. I would compare it to an iron.
BD
   / Magnetic Heater for tranny or engine block? #6
I have used one on the oil pan- works well, it gets VERY hot- be careful. In anohter thread someone suggested that if you use anything that requires an extension cord to put the cord thru the steering wheel- as a reminder that it is there. I wish I had known of this tip a couple years ago. The other tip is to use a timer set to go on a couple hours before you plan on using the tractor. I have a scrap of metal that I stick mine to when it come off the tractor- no need for a very hot item to just be laying around!
for the price I think you will find it worth it.
   / Magnetic Heater for tranny or engine block? #7
Doc Bob:
I agree with bigdad they get pretty hot :eek:, but they have a handle that is heat resistant. I put my hot magnetic heater on my tiller to cool off.
RFB: I never tried one of those oil pan heater pads. I read somewhere (without further research) that those pads tended to "bake" the sludge in the oil pan so I never tried one of those. The theory behind the heater pads seems valid. Jay
   / Magnetic Heater for tranny or engine block? #8
jbrumberg said:
Doc Bob:
Not sure if they would "bake" the oil or not. IMO probably not. Think about it for a second. As the oil in the bottom of the pan heats up it will start to rise and be replaced with colder fluid. Just like hot air rises so does hot fluid. Granted it will not be circulating like when the engine is running but it will circulate some. Same principal as how older tractors without water pumps cool. The hot coolant rises out of the engine block through the radiator and is cooled, fed back into the engine and flow's back down through the engine. You would probably have to leave it on there for a long time to cause any problems. Nothing a timer wouldn't prevent though.
   / Magnetic Heater for tranny or engine block? #9
Why not just throw an insulated fire resistant blanket over the tractor and place a small electric heater with fan under it. Heat the whole tractor including the seat!:D
   / Magnetic Heater for tranny or engine block? #10
Has anyone ever checked to see how warm their transmission actualy gets in the winter when they are plowing snow. I have used engine oil pan heaters before on cars and they work good. But they are only heating 6qts of oil. How big of a heater would you need to warm up 10 gal of oil and how long would it take. Would the thick transmission case disperse the heat before the oil could get warm.
2015 LEDWELL LW48 HTHT2 48FT  HYDRATAIL TRAILER (A45678)
2015 LEDWELL LW48...
275 GAL HORIZANTAL SKID TANK (A48992)
275 GAL HORIZANTAL...
2012 Dodge Grand Caravan (A46684)
2012 Dodge Grand...
2019 Ford F-550 V-Mac DTM70 Air Compressor Flatbed Truck (A48081)
2019 Ford F-550...
Raccoon RC-G4.0 Golf Cart (A49251)
Raccoon RC-G4.0...
1990 MACK CH WATER TRUCK (A48992)
1990 MACK CH WATER...
