Magnets in Transmission Suction Screen - JD 2305
   / Magnets in Transmission Suction Screen - JD 2305 #1
KestrelMerlin
PA
John Deere 2305
I'm doing the first transmission oil and filter change on a John Deere 2305 and I've never done a tractor before.
Inside the cylindrical transmission suction screen, there are 4 bar magnets - each about 3/16 x 3/16 x 3 inches. When I took the magnets out, they were all clumped together instead of being evenly distributed around the cylinder.
The polarity is such that reversing one magnet end-for-end does not help. When any two are brought together, one will rotate on the long axis and they are strongly attracted to each other.
Anyone know if there is a way to keep the magnets separated?
BTW - I had a hard time getting the retainer cap that holds the transmission screen out of it's socket. It is supposed to be held only by two o-rings after the end clamp is removed, but it was also held by paint that seeped into the gap.
   / Magnets in Transmission Suction Screen - JD 2305 #2
I have the same issues as you each time I change the fluids. Now I just try to keep the magnets apart until I put it in even though they are always back together the next time. For me, that cap never got any easier. Maybe someone else on here knows a trick. Good luck
(2) Pallets of Implement Parts (A50121)
(2) Pallets of...
1996 International 4700 Box Truck, VIN # 1HTSCABP2TH265415 (A51572)
1996 International...
2013 Ford F-450 Altec AT200A 30ft Bucket Truck (A50323)
2013 Ford F-450...
EZ-GO Electric Golf Cart (A50121)
EZ-GO Electric...
2014 Chevrolet Cruze LTZ Sedan (A50324)
2014 Chevrolet...
