Mahindra 2538 vs 2555
   / Mahindra 2538 vs 2555 #1
aerojunkie
Kannapolis, NC
Mahindra 2538
Ok, I got a bit of a wild hair and could use some information and recommendation please. Im tempted to go about trading my 2538 for a 2555 but cant decide. I love the small size of the 2538 and I can seem to get anywhere I want to work, but how much bigger is the 2555 in actual usage? My only real gripe is I wish the loader on the 2538 was a little more, with more breakout force. Do you guys with the 2555 find it able to get in small spaces? And do the 2538 owners out there have any problems with its capabilities? I know I have thrown out a few options I was thinking in the past including a backhoe to help with the digging, but cant make up my mind and could use a few opinions or thoughts please.
   / Mahindra 2538 vs 2555 #2
You and I have talked about this a little. I love my 2538 but really want a cab. If I am going to do that I may as well get a little larger tractor. Turning radius is a little bit larger on the 2555. Height is about 8 inches from my rops to a 2555 cab. Width is the big diff. I would think the 2555 is quite a bit more stable. The only thing I hate about the 2555 is the rear tires. They look like balloons. Maybe they are over inflated at my dealers. I am talking about the r4's. I think the bucket may work better on the 2555 due to the different hinging by the bucket. Hopefully no dead spot. I also see that it moves quite a bit slower. I like that idea. When I use a bucket I am not in a race. I am at 17200 plus my open station 2538 to go cabbed 2555.
That we have, ever since you started posting things on trading in it got me thinking that maybe I wasnt the only one looking into that. I haven't test drove one yet mostly cause im afraid I'll like it to much.lol. Something I really like on the 2538 is being able to stand up on mine and see the bucket edge on the ground, not sure if the 2555 would be the same. Have you used the loader on a 2555 some? Just curious if it has the same valve and also somewhat hard to make minor adjustments. One thing I will say, judging by the info under members names there are a lot of 2538s and 2555s out there.
   / Mahindra 2538 vs 2555 #4
FWIW,
I LOVE my 2538. It's done everything I've asked it to and more...except for lifting 1600 lbs with bucket forks...
I've found that if I increase my RPM's to 1800-2000, I get much better performance from the bucket and "break out force". Just moved 13 ton of surge rock (size of your fist), without a glitch or even a moan from the 2538. Today I dug 40 post holes 36-40" deep in clay. Never had a problem with bogging down at all.
2 days ago I mowed 5 acres with a 7' pull behind grooming mower. Lifted it without a problem, ran it at 540 PTO RPM without a hitch.
I wish I had a cab for it, but the cost is prohibitive as an add-on. I also wish the bucket were a little bigger, but it dwarfs my buddies Kubota 34 horse bucket. But even if they made it a little bigger we would probably still gripe, unless it was the size of a CAT front loader....:laughing:
And screamin400 solved my 3 pt hitch lever issue. Works like a charm now. Thanx!
If 20 extra horses and a bigger frame are worth it to you...go for it. But I'll keep my 2538. Just my $0.02
Good luck on your decision.
   / Mahindra 2538 vs 2555 #5
i have 2555 open station. it is great. 6ft cutter no struggles at all. the only time engine bogged down a bit was pushing the front bucket into dirt mound. no turning problems and i have a lot of woods , seems to turn pretty tight to me. i am so happy with hp. the hoe is a bit disappointing. the dipper doesnt have quite the power. i was hoping for. but you can get dig fine since the bucket seems to have more capability to scoop. still glad i got it. also have 6ft BB no struggles. also have hst so it is no problem to back up/go forward whenever needed in tight space.
   / Mahindra 2538 vs 2555 #6
Hello, I also have a 2555 HST open station and it has 75B backhoe. I am very happy with loader lift capacity and backhoe digging capability. I have taken it into my 10 acre woodlot 2 or 3 times per week (with backhoe attached) for the last 5 months with no problems. I have only owned this machine since 3/16 (have 135 hrs. on it now) --and would say there are not any difficulties with operations in the woods. However, I have not driven a 2538 under same circumstances for comparison. Also - I can see front edge of bucket when it's on the ground when I stand up in the operators platform (am 6'4" tall). In addition - when the ROPS is folded - it will fit thru my 9' wide x 7' tall overhead garage door - but backhoe has to be swung sideways to close door on my 24' deep garage when grapple is on the loader. (A new single bay garage with 9 x 9' door is in the planning stages). Overall - very satisfied!
   / Mahindra 2538 vs 2555 #7
Here is what I think I know. Not sure but think so. Foot pedals are electronic on the 2555 and work better and easier than ours when I drove one. No creeping that I saw. The loader works slower and smoother but again this was sitting in the dealers yard. Seat is better. Has a cupholder. I need that for my phone. More hp but not as much more as I would have thought. 17 more at the motor and only 10-12 more at the pto. Tractor has a turbo. I love my turbos. Lower rpm and more torque than without. Now the question is can I get the same tune as the 2565 :) and still have the hst work right? I wonder if it can lift a ton of pellets? My 2538 with forks cannot lift much. With bucket it is fine but forks are pretty lame. The tilt back is very weak even with the bucket. Seat is better on the 2555. I put a different suspension under mine but makes the pedals a little further away. Cruise control is nice. I just put it on my 2538 and love it. Rear hydraulic is nice as I will put a hydraulic upper link on my box blade. I use the blade a lot. The tractor is 71.5 inches wide. Just barely fits my equipment. I would be going to a 7' box blade and probably a grapple if I get the 2555. My tiller will hardly cover as it is 6'. If I had a 7' tiller I may look at the 3550 but tiller is new and I do not want the extra weight of the 3550 even though it is a nicer tractor. Brake lever is backward on the 2555 and is electric if I recall. You pull up to lock the brakes. Turning radius is larger and that is an issue for me but I will get over it. Cost is the only thing holding me back at 17k plus my 2538. I have over 200 hours on my 2538 now. Great tractor but hoping to get her bigger sister.
FWIW,
Thanks Duffer. My 2538 has been a great machine so far and the only times ive had second thoughts is when I go to lift something that is just out of reach for the loader. The general hp and even bush hogging has been a non issue for me, only those times the loader needed probably a few hundred more pounds of lift or curl.
Thank you mikeman and hkbirdman. It seems like you guys have had really good luck doing exactly what I want to do with mine, makes me want to trade even more. Seems its still a very agile machine and will get where I want to, it just looked way to big sitting on the lot but I here once you get them home they shrink. I have a lot of small stuff to do around the house as well as in the woods since its the only one I have with a FEL on it so being able to move around close to things and get close with the bucket is important to me.
Thank you for sharing you findings screamin400, sounds like we have the same issues......just different versions on 2555 we are after. Im hoping to go to my dealer this Friday and get a closer look and test drive. I need to get the filters for my 50hr service so may as well see if I will need them for a 2555 instead.lol. I keep finding uses and racking up the hours faster than I really thought I would, Im actually at 60ish hours and its only been 2 months that I have had it. Not bad if I was a farmer for a living but this was just something for my personal use. It all depends on what my dealer says he can do and how bad I would lose my but if I trade on not, what I have is getting it done just a few things I wish it did better. Another big thought is Im only on 6 acres, not 60 so the upgrade is harder to justify for what I really need.
   / Mahindra 2538 vs 2555 #9
Is the 2555 a large CUT or is it a utility size tractor?
   / Mahindra 2538 vs 2555 #10
forgot to mention the model hoe is 65B. as soon as i got the tractor i put dielectric grease on every connection and used paint pen to mark most of the bolts that might come loose over time so i can tell visually if they loosen. once its dirty it is 3x the amount of work to do it. ran it for about 10 hours this weekend cutting grass/brush, knocking down trees, grappling etc. put on a few of 4 inch pvc pipes to hold fire ext. and to hold chainsaws.
   / Mahindra 2538 vs 2555 #11
My take is the 2555 is a large CUT, not due to it's HP but because of it's weight/frame build. The 3550 [ or older 5035 ] is a lot heavier build, pushing into the utility size or real close [ quite a bit heavier and larger tires ].... Both are real nice tractors....
   / Mahindra 2538 vs 2555 #12
3550 has almost same pto power as 2555. Wish it wasn't quite so wide
   / Mahindra 2538 vs 2555 #13
Its the same width as the 2555 if not more narrow I would think?
   / Mahindra 2538 vs 2555 #14
3550 is about 4 inches wider making my new 6' tiller too narrow
   / Mahindra 2538 vs 2555 #16
I was looking at the specs yesterday on the 3550 and it comes listed as something like 75.5 inches wide with ag tires. r4 tires are wider. Would have to narrow up a lot. It is a heavy beast for sure. I really don't need the weight too much but figure weight is usually strength. More for my truck and trailer at the same time. The 3550 loses less to the pto than the 2555 and no one can tell me why. Dealer told me yesterday that Mahindra is releasing 30 new models at the meeting. This could be anything from tractors to attachments to utv's.
   / Mahindra 2538 vs 2555 #17
I am demoing a 6065 right now - not released yet. I believe the 6000 series will replace the 5000 series but don't quote me on this. It seems the 6065 is a gap filler between the 2555 and mPower 75/85 (cabbed models) - it is one heck of a machine.
   / Mahindra 2538 vs 2555 #18
The 6000 series is a beast!
Went yesterday and got the details of trading in from my dealer, I have a feeling the 2538 is here to stay.....at least for a while. The cost difference of about $8000 could just be financed out but probably looking at a loss of somewhere in the $2000-$2500 range to pay most of upfront but hard to say unless he saw the tractor and got things going. He said the 2555 is an awesome machine with a lot of power, but there is a reason he doesn't have one on the lot, they are a good deal bigger. He said if you have the room to use it they are wonderful but most of his sales are people needing a smaller more maneuverable tractor that didnt have to run larger implements and this is what he recommended. So Im thinking just spend the money on attachments for my 2538 like a backhoe and grapple.
   / Mahindra 2538 vs 2555 #20
I am 17k diff only going to a cab. I think you got a better price than I did
2003 CASE 590 SUPER M BACKHOE (A60429)
2003 CASE 590...
SWICT 60" SKID STEER BUCKET (A60430)
SWICT 60" SKID...
Bobcat A770 (A60462)
2017 Toyota Tundra SR5 Ext. Cab Pickup Truck (A59230)
2017 Toyota Tundra...
1981 LINK BELT HSP 8028 (A58214)
1981 LINK BELT HSP...
2023 KRT ST650 STAND-ON SKID STEER (A60429)
2023 KRT ST650...
